turbo manifolds for 4th gen
Old Dec 4, 2010 | 06:31 AM
  #81
bryan163's Avatar
fixed
Old Dec 10, 2010 | 09:32 PM
  #82
aic96max's Avatar
if youre going to make solid mounts, why even bother with all that there and not just make an L plate solid mount that will eliminate the oem bracket and leave a whole lot of more space for piping??
Old Dec 11, 2010 | 05:05 AM
  #83
t6378tp's Avatar
Turbo 3.5
I guess you plan to use a slip joint clamp with this mount. I agree with the op too much work I would just make a solid L shaped mount and call it a day.
Old Dec 11, 2010 | 10:10 AM
  #84
ampire's Avatar
That motor mount design is clever.
Old Apr 2, 2011 | 11:52 PM
  #85
BlackMamba's Avatar
I know nothing about turbos or anything FI, but i have to ask, why not a
manifold without touching the radiator nor the motor mount ? rear facing maybe could be a solution ?
Old Apr 3, 2011 | 08:08 AM
  #86
TurboA32's Avatar
I didn't know that kobe bryant drives a maxima lol
Old Apr 3, 2011 | 10:03 AM
  #87
BlackMamba's Avatar
And he loves it
Old Nov 14, 2011 | 03:57 PM
  #88
VincentXero86's Avatar
I'll be happy when my turbo comes through the door
Old Nov 21, 2011 | 03:31 PM
  #89
I'll be happy when my turbo comes through the door ;D
Old Nov 15, 2012 | 01:32 PM
  #90
MaxiMike's Avatar
Originally Posted by bryan163
I will be getting the car dynoed some time before the spring, but like streetz said results will vary greatly. I'm making 16lbs of boost with a JWT ECU, Z32 MAF, and 370cc injectors and it is maxed out on these injectors right now which means probably somewhere around 425hp.
What kind or from what car did you use the JWT ECU and 370cc Injectors on you car??
Old Nov 16, 2012 | 01:11 PM
  #91
TurboA32's Avatar
He used a 96 maxima ecu and 300zx injectors
Old Feb 5, 2013 | 07:52 PM
  #92
P0tter7's Avatar
would i be able to use 300zx injectors on my 3.5swap? i mean let me be more into the question. im doing a 3.5 swap. if i put them in there with the fuel regulator would it hurt it if i dont go on with the plan on turboing it in the fuctuer?
Old Feb 5, 2013 | 09:18 PM
  #93
ShocknAwe's Avatar
^ get rid of that sig dude come on
Old Feb 6, 2013 | 11:09 AM
  #94
maxgtr2000's Avatar
KH3 by popular demand
No the injectors are different, side feed in the 3.0, top feed in the 3.5. You should find out what other differences there are between these 2 motors.
Old Feb 6, 2013 | 12:28 PM
  #95
bryan163's Avatar
It is possible to run the side feed injectors and rail on a 3.5 if you use a 4th gen intake manifold. However, you will need fuel management when using larger injectors.
Old Feb 10, 2013 | 10:40 PM
  #96
P0tter7's Avatar
ok thanks, i read alot on the computer but 9/10 says the same ****.
and almost everyone i see people say do research like instead of sayin why dont u just help someone out. thats why i joined here to ask people point of veiws and to find out info. well u cant find the info if everyone wants to post the sae ****(research) like im clealy trying.
Old Feb 11, 2013 | 02:35 AM
  #97
95naSTA's Avatar
This is info you could have found through research. People probably told you no because there's hardly a reason to run side feeds on a 3.5.
Old Feb 12, 2013 | 04:43 PM
  #98
P0tter7's Avatar
i was just curious. i have been thinkin of a 3.5 swap plus turbo. and now my mind is stuck on it. im looking for a motor now and then looking for the turbo setup and doing it all at once. i like the ideas off of here. i like the motor mount idea.
Old Feb 23, 2013 | 10:39 PM
  #99
Snowbiker's Avatar
Do you have any internal work done or is this on a stock motor?
Old Feb 28, 2013 | 09:19 AM
  #100
TurboA32's Avatar
He used a completely stock vq30de.
Old Mar 5, 2013 | 03:40 AM
  #101
Snowbiker's Avatar
How long have you been driving it turboed?
Old Mar 6, 2013 | 01:39 PM
  #102
TurboA32's Avatar
What does it matter how long he's be driving it turbo
Old Jan 10, 2014 | 05:13 PM
  #103
00maxima-600rr's Avatar
So u still making this custom set ups???
Old Jan 28, 2014 | 09:28 PM
  #104
JonBlz's Avatar
a.k.a. STuNtMAN
pm sent still waiting on response
Old Apr 4, 2014 | 06:17 PM
  #105
I<3 A32's's Avatar
ill buy one when i have all the components to the turbo kits
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
