2011 Backyard Turbo Build
Old Jun 5, 2011 | 02:37 PM
t6378tp's Avatar
Turbo 3.5
I figured it's about time to make a new build thread. The plan was to make something different, spool faster and resolve a ground clearance issues by running the downpipe under the oilpan instead of the tranny.
When making the setup I was planning to run my masterpower turbo and a car with no abs. Well I found out after the setup was basicly done that my turbo was bad, the car I was going to get was sold and that I would have to use a drivers sid slim fan or delete it. Plus due to the design of the 350z headers a few of the bolts were alittle hard to reach. Due the price I was quoted for a rebuild I figured it cheaper to just buy a holset hx35, sell the setup and start over.
The plan was to make a det style setup with custom headers, clear the fans and abs unit, bolts easy to reach, run the downpipe under the oilpan, face the turbo behind the driverside head light and just a overall easy install.
I was going to make the headers equal length but felt it wasn't worth the hassle at my projected power level. I am going to make a setup like mine for a local org member with equal length headers and a 3.5 to 4inch downpipe running out the fender, no exhaust "shooting for 650-700fwhp"
Here is a pic of the old setup which is already sold and maybe installed already.
Old Jun 5, 2011 | 02:41 PM
t6378tp's Avatar
Turbo 3.5
Here are some pic's of the new setup. I just got some 350z headers and cut the flanges off.
Rear Header
Old Jun 5, 2011 | 02:47 PM
t6378tp's Avatar
Turbo 3.5
Front Header and Fan Clearance
Old Jun 5, 2011 | 02:56 PM
t6378tp's Avatar
Turbo 3.5
Downpipe to motor mount clearance, Downpipe to Fans, Downpipe to Oilpan and Crossoverpipe to starter clearance
Old Jun 5, 2011 | 02:59 PM
t6378tp's Avatar
Turbo 3.5
So before the downpipe was made I mounted the holset and didn't like the way it looked. Nothing wrong with the turbo it's just not the prettiest thing so I took a stab at rebuilding my masterpower and it worked. Tested it on a local members car and it was fine so I cut the t3 holset flange off and welded a t4 flange and bought a 3inch v-band for the downpipe. Also the Masterpower turbo over all is a smaller unit althou the wheel is bigger than the holset.
Here are some pic's with the turbo mounted and the downpipe poking out the oilpan. Now I just need to install a 3inch flex and figure out the wastegate location.
Ok so the flex section is welded along with the waste gate. The pipe runs over the upper rad hose between the rad and front valve cover. I was going to route the dump back into the exhaust but changed my mind and just going with a open dump
I'll take some pic's later now
Old Jun 5, 2011 | 03:00 PM
t6378tp's Avatar
Turbo 3.5
pis of the crosspipe and waste gate flange, I'll upload a pic of the downpipe with flex section later
t6378tp's Avatar
Turbo 3.5
Should be it
t6378tp's Avatar
Turbo 3.5
Just Encase
Old Jun 5, 2011 | 03:48 PM
maxspeed96CT's Avatar
The original VQ...
have a link to some larger pics ?
looks good btw
Old Jun 5, 2011 | 03:58 PM
t6378tp's Avatar
Turbo 3.5
looks good btw
http://www.cardomain.com/ride/250874...maxima/page-13
Old Jun 5, 2011 | 04:24 PM
Kevlo911's Avatar
Kevlo for President
I like it.
Old Jun 5, 2011 | 05:10 PM
t6378tp's Avatar
Turbo 3.5
Originally Posted by Kevlo911
I like it.
Old Jun 5, 2011 | 10:33 PM
Unklejoe's Avatar
WTF thats bad ***
I like what I see so far.
Old Jun 5, 2011 | 11:02 PM
itwillrun's Avatar
Looking good but your shooting for 650 to 700fwhp ? A holset35 wont put you even close and that will cost you around 100k or more if you wnat it to run after that dyno session. Definitely looking good though.
Old Jun 5, 2011 | 11:31 PM
Unklejoe's Avatar
I don't think he was referring to his build. He said he was build another setup for another member.
Old Jun 6, 2011 | 08:26 AM
t6378tp's Avatar
Turbo 3.5
100k to make 700hp, lol
Like stated, that is another build and I not using a holset. I rebuilt my T61 turbo and going to use that, it should be good to around 450-500fwhp but I am only shooting for around 350-400
Old Jun 6, 2011 | 06:24 PM
itwillrun's Avatar
It would take a good 100k that's why I asked. 350-400whp is nice, after that you would probably lose must streetability of the car. What are you running as far as suspension and tires ? Also oem axles ?
Old Jun 7, 2011 | 04:38 AM
t6378tp's Avatar
Turbo 3.5
it doesn't take 100k to make power, already seen it done
Old Jun 7, 2011 | 09:41 AM
itwillrun's Avatar
Lmao you've seen it nice. I've done it. No way is the transmission, ignition, axles, suspension brakes, chasis, cooling system, or most of the rest of the oem car going to be able to handle 700fwhp or 800bhp. Once you get to a certain point power becomes very very expensive and there can be no cutting corners. Here is a 82 firebird I built and tuned for a kid. 343 small block fully built running a t88 on 20 psi. Block and fuel injection were the only parts of the car done good enough imo, and now the car is gone unfortunately. There was well over 50k in parts into that car alone. And making power out of a 343 is much easier.
Old Jun 7, 2011 | 10:11 AM
Unklejoe's Avatar
I personally know someone with a 620whp 8th gen civic on a completely stock drive train.
Old Jun 7, 2011 | 11:09 AM
itwillrun's Avatar
2 totally different cars and just because the dyno said 620whp there is no way he drives around with more than 400hp and those axles last. Civic's snap axles all day.
What are you running for tuning ? The welds and rest of the setup all looks pretty good.
Old Jun 7, 2011 | 04:06 PM
t6378tp's Avatar
Turbo 3.5
not looking to go back and forth, I have other cars, be there, done that, made the power and know people that have made the power with nissan and other makes it can be done for less than 100k.
As for tuning this time since I am going shooting for 300DD and 400hp weekend/track a safc2 and meth on stock timing will do. Maybe later down the line I'll swap out the safc2for a AEM piggyback.
Old Jun 7, 2011 | 11:45 PM
Unklejoe's Avatar
How come you're not using that JWT ECU that you had?
I remember you mentioning that you had them make a nice custom timing map with like 17 degrees of timing.
Old Jun 8, 2011 | 03:55 AM
wirelessdude04's Avatar
Tom your at it again can't wait for this one...
Smh 100k to make 700hp
Old Jun 8, 2011 | 04:51 AM
t6378tp's Avatar
Turbo 3.5
I doubt if the person who bought the ecu will sell it back so safc2 it is. I called myself getting out of the maxima game, sold everything but then turbo, waste gate, exhaust and suspension then I started to miss having a boosted car and now need a sedan for the family. I was going to boost my G35 but the warranty does run out till next year so I am going to turbo max till then.
I was also thinking about trading in my G35 coupe for a 07 G35x sedan and making a twin turbo kit for that but I am still researching the awd system and it's limits
Old Jun 8, 2011 | 05:06 AM
t6378tp's Avatar
Turbo 3.5
Well it will be a black 95-98 with tint, 19inch rays, s-techs, 3inch exhaust, turbo, 00vi swap, full audio/video and yellow fogs
Old Jun 8, 2011 | 07:10 AM
WhoDatBuuL's Avatar
yo tom this is goin in my car right ? LMAO
Old Jun 8, 2011 | 09:40 AM
hehe..... Forgot a front lip
Old Jun 8, 2011 | 12:59 PM
t6378tp's Avatar
Turbo 3.5
Lol, yeah that too
Old Jun 8, 2011 | 02:37 PM
Ninety9gle's Avatar
Nice. hopefully I'll get to see this one in person
Old Jun 8, 2011 | 07:22 PM
t6378tp's Avatar
Turbo 3.5
Sure, I have everything already besides the car and front lip so it shouldn't take much more than a three day weekend to transform the car from bone stock to a lower, boosted and tuned monster
Old Jun 8, 2011 | 07:52 PM
itwillrun's Avatar
Yo if it's cool with you lets set up a meet when your all done. Jermaine can be in charge of the location etc. lol, I don't mind driving out there it's only a bit more than an hour for me.
Old Jun 8, 2011 | 09:25 PM
Ninety9gle's Avatar
damn! you make it sound so easy lol.
edit* so is this one gonna be auto?
Old Jun 9, 2011 | 01:11 AM
Unklejoe's Avatar
You should bring this killer out to some meets when its done.
I've been hitting up the sonic in bensalem a lot lately. It's a pretty nice meet.
Old Jun 9, 2011 | 04:28 AM
t6378tp's Avatar
Turbo 3.5
that's fine
it's really not that bad, I have air tools and a flat driveway. The hardest thing will be removing and installing that rear ehaust manifold. Pretty everything is done, oil pan welded, injectors installed, fuel rail, intercooler piping layout, springs and shocks/struts assembled, radio and screen rewired and fitted into radio trim already and etc
5spd only
I was just at sonic last week with my G35 and a few local members, one with a boosted 4gen and the other with a audi s4 twin turbo.
Old Jun 9, 2011 | 03:07 PM
jovani4183's Avatar
Why Not try the unichip piggy back?
Old Jun 10, 2011 | 11:50 AM
t6378tp's Avatar
Turbo 3.5
I don't think that will even work on these ecu's, plus if I could get that to work than I would just use osiris
Old Jun 10, 2011 | 02:05 PM
tedo007's Avatar
faster than you think
Any chance of you making replica of the downpipe? You could make some extra money.
Old Jun 10, 2011 | 04:06 PM
t6378tp's Avatar
Turbo 3.5
I could but it's kinda hard to make a downpipe without the feedpipe. But I could make the downpipe just like mine and the buyer could make a feedpipe that would bolt to it
Old Jun 10, 2011 | 09:22 PM
aic96max's Avatar
this looks great, you think this can be installed without pulling the motor? congratz man, kit looks good so far
