Need help...turbo kit installed
Old Nov 29, 2009 | 08:35 PM
BkGreen97's Avatar
My turbo kit is finally installed, with few things missing and minor difficulties..
It is a custom kit, used turbo and have a huge problem.
I can spin the blade of the turbo by hand but when the car is on, and idling even with load on the engine... the blade dosent turn by itself... what could it be? Need help asap...
Old Nov 30, 2009 | 10:30 AM
streetzlegend's Avatar
ur going to have to give more information than that. How are you putting load on it? are you driving around or this is in neutral. what size turbo is it? If you have a big exhaust housing its not going to spin at idle, you would have to put REAL load which means actually drive the car and go through the gears. I had a t04b and it woudlnt spin at idle. Is the oil supply to the turbo done properly, is it getting oil?
Old Nov 30, 2009 | 10:51 AM
BkGreen97's Avatar
ok well it is a full t4 front side .70 a/r exhaust side .84a/r ... it dosent spin at idle but it does spin with reving... i think it just needed to be primed because it sat for a while...
im glad to know they dont all spin at idle...
Old Dec 1, 2009 | 04:42 PM
akurtzer57's Avatar
That is a pretty big exhaust housing. It will spool up in the upper rpms. My t04E spun at idle that was a .63 a/r
Old Dec 1, 2009 | 07:30 PM
maxgtr2000's Avatar
KH3 by popular demand
Mine slightly turns at idle (t3/t4 .63 a/r), sometimes it doesn't, if it turns when you rev you should be okay. You can double check for leaks in your feed pipe as well.
Old Dec 2, 2009 | 05:12 AM
BkGreen97's Avatar
problem now is my alternator went and the car dosent go past 2500 rpm when it does get started.... my oil drain wasnt tight enough and their was white smoke coming from the turbo.... and i havent boosted the car yet, the car shows me no boost at all no matter how high i go in the rpms when i could've
Old Dec 3, 2009 | 06:34 PM
aic96max's Avatar
guys using a t3/t4 will spin at idle, full to4s may not spin at idle but you should see some boost when you drive the car and the engine is loaded. not really a given just in neuatral revving it. I had a to4b with a .69 turbine housing and i dont think i could rev it in neutral to see boost. this is not a belt/rpm driven thing. you need to drive the car and load the engine, especially with a .84 ar, is it on center? tangental? i would look for a .58 housing for that turbo, or its gonna be a pig for a little bit. make sure the drain is not backing up, and also check for pressure under high rpms, i was putting too much oil in the turbo and it would smoke , needed to use a restrictor
Old Dec 4, 2009 | 05:34 AM
BkGreen97's Avatar
my drain line is a bit long and this is a dip then it goes back up into the pan is that alright ? or should there be a straight downward slope to the pan?
Old Dec 4, 2009 | 05:47 PM
maxgtr2000's Avatar
If there is a dip it will smoke, it needs to be downward sloped as you said. If you fix it and it drains enough not to smoke under boost you won't need a restrictor. Give it a little time to smoke out the excess oil it may not be a right away thing, there may be oil residue in the exhaust, etc.
MaxLife17
Jun 27, 2019 01:37 PM
mpbclutch33
Sep 8, 2015 06:21 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
