Super charger pulley question.....
http://forums.maxima.org/supercharge...lbs-boost.html
I think 2.62 is 15lbs but you are over spinning the blower if you arent using the T-trim or S trim I forget the name of it. Its on vortechs site.
V1 or V2? And he's right, their site has some pretty good info.
From the boosted sticky
The 2.87 will be the one closest to 14lbs, the 2.62 will be above that range.
If your running the S trim, you will be overspinning the blower and will shorten its lifespan.
What does your fuel setup consist of?
I was able to hit 13lbs on my V1 S trim, but that was at 7k.
I now see well above that at 6500 with my Si trim running the 2.87 pulley.
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
