Engine blowing oil, now what?
Old Aug 16, 2010 | 07:56 PM
  #41
Kevlo911's Avatar
Kevlo for President
Originally Posted by MarcL
I am using a Kenetix 350Z intake with the SC setup, so I dont think the plastic intake will do me any good.
To run the VQ30 ECU, I need to change the timing chain/gears/and related components too.. NO? Will they fit on the Altima heads if it is taller (as I have read here)?
the heads aren't taller.
only the rwd motor has the taller block now and that is the HR motor.
Old Aug 16, 2010 | 08:11 PM
  #42
MarcL's Avatar
So, a 2008 Altima or Maxima will work? They went to HR in 2009, right?
The trans bolt pattern will not be a problem either, that was only changed for HR too?
Old Aug 16, 2010 | 08:13 PM
  #43
MarcL's Avatar
... and I would need to re-drill the cams, I assume they wont be the same as the ones I have?
Anyone know where I can get a template for the drill spot? even if I can reuse the cams I have, I want to make sure they were drilled correctly.
Old Aug 16, 2010 | 08:25 PM
  #44
Kevlo911's Avatar
Kevlo for President
HR is only RWD cars.
I do not know if there is a template for the cam drilling. I assume you just try to make them match the 30?
Old Aug 16, 2010 | 09:01 PM
  #45
MarcL's Avatar
I don't have a set of 30 cams to compare them to.
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
ag90fox
Sep 9, 2015 12:22 PM
jwright36
Sep 8, 2015 11:45 AM
