For those that make your own feed pipes.
Old Dec 16, 2010 | 07:20 PM
streetzlegend's Avatar
I have a question for those of you who make your own feed pipes. Have you ever tested or compared how the turbo responds to different feed pipe diameters? For example a 2.5" vs. 3". In my understanding/logic I assume it would take longer to fill the volume of a 3" pipe vs. 2.5", therefore taking longer to start spooling the turbo, however once its spooled up the engine will exhaust more and produce more power.
Old Dec 17, 2010 | 11:01 PM
akurtzer57's Avatar
It all depends on your setup. Some people have run 2.5 and switched to 3 and saw some gains on the dyno. What are your goals?
Old Dec 17, 2010 | 11:51 PM
well i currently have 2.5" from engine(collector at the ypipe) to the turbo, so was curious if 3" would yield more power. But there is just too much physics/math behind figuring it out, so wanted to see if anyone had tried different diameters.
Old Dec 18, 2010 | 07:46 AM
maxgtr2000's Avatar
KH3 by popular demand
For your 3.5 I would say go for it, you could sell your old feed no problem if you decide to go for the 3". There is a new thread in 4th gen on that obx 3" y for an rmt, but I don't think anyone tried it yet.
Old Dec 18, 2010 | 09:03 AM
Well I was talking to Kevlo about it, and I think ill stick to my 2.5". I dont think we have enough RPM range to benefit from 3", id have to do something about having a better spooling turbo, smaller housing, quick spool valve or something. With about 10' worth of piping, going from 2.5 to 3", there is a big difference in volume to fill and pressurize, so I dont wanna spend all the money doing 3" to find out my spool up curve moved more to the right lol. I already get late boost (full boost at high 4k and shift at 6k)
Old Dec 18, 2010 | 10:46 AM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
That is probably right. The 2.5" is not likely choking it up enough to offset the reduced spool time. Are you using a dual scroll turbocharger? If so, there's no reason not to use a quick spool valve... They can be kind of expensive or difficult to fabricate, but I see tons of good reviews about them.
Old Dec 18, 2010 | 10:59 AM
t6378tp's Avatar
Turbo 3.5
the only way it would be worth switching from 2.5 to 3inches is the following:
1.
you plan to extend your rev limiter
2.
the new feedpipe will be shorter and to make the total volume between the two setups the same. If not your turbo will spool slower
Old Dec 18, 2010 | 11:38 AM
I have a twin scroll, fabing one up is actually pretty simple but no time, and i REFUSE to pay $500 for a SP spool valve, they have it patented and no one else can produce/sell it so they charge insane amounts.
Old Dec 18, 2010 | 11:45 AM
1.
2.
Yeah, im sticking with what i got
Old Dec 18, 2010 | 01:31 PM
BkGreen97's Avatar
well my feed pipe went is FULL 2.5 until it crosses the front motor mount then as it get to the t4 flange it is a large as 3.25 oval bent...
Maybe that was my problem with boost in first gear, on my little old 3.0
Old Feb 25, 2011 | 01:23 PM
t6378tp's Avatar
Turbo 3.5
you ever think about running two seperate exhaust pipes from each bank into the turbo.
Old Feb 25, 2011 | 01:25 PM
That's certainly doable, but probably wouldn't do anything more than Y-ing them together into the turbo and no ability to use a spool valve.
Old Feb 25, 2011 | 03:37 PM
t6378tp's Avatar
Turbo 3.5
it would if he has a twin scroll turbo which most holsets are, remember that divider is there for a reason
Old Feb 28, 2011 | 10:10 AM
k20tek's Avatar
OWES MEMBER MONEY - DO NOT BUY FROM k20tek
whats a spool valve
Old Feb 28, 2011 | 12:30 PM
furbiss112's Avatar
From what I know, 350Z guys were losing power when they went to 2.75 primary pipe for headers. The 2.5 were the best for power.
Ferhan
Old Mar 2, 2011 | 09:34 AM
TurboA32's Avatar
you guys are funny
Old Mar 3, 2011 | 08:41 AM
aic96max's Avatar
make a forwared feedpipe!!! shorter and better flowing. say what you want, on my old car i made full boost 1st gear on a 3.0... lol yes still hating just a little lol come tune 2 cars and put some cash in the y-pipe fund
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
05RLS2
Sep 27, 2015 09:24 PM
A32goldylocks
Sep 16, 2015 01:33 PM
thenewguyy
Sep 12, 2015 11:12 AM
