Max_King's Newbie Turbo Build
Old Jan 15, 2012 | 05:21 PM
  #81
SurraTT's Avatar
HR Swap Pioneer
Originally Posted by 2000_MAXIMA_KING
Yea after I switch jumper 13 to open it'll be prefect.
Thanks for all your help! I have to say I was really surprised with the quality of your harness, not to say I was doubting you but you made it so quick and it is so well put together. Also, the use of bigger gauge wire is a plus, I'm an electrical engineer so I know a thing or two about wires and seeing the use of the right gauge is impressive since others skimp out on this important concept. In order to eliminate voltage decay and keep the correct level of voltage across the signal the right gauge wire is essential.
With the other harness exactly what you just said happened. I found one of the pins for the injectors had actually broke off and even after fixing the harness it still was causing multiple codes to be thrown for various signals including MAF, CKPS, etc. I was losing voltage all over the place and the fact they used 22 gauge wire voltage signals were weak. You can look at the emails above and see all the details.
Anyway aside from all that the car will be getting a rough N/A tune so I can gain some experience with the use of the EU. It's freezing cold in my garage and I've been so busy with work that the turbo build will have to hold off for a bit of time. I actually will be out of town this coming week so nothing will get done till I come back if the weather permits.
Cool!!! So your running Danymax write up ?, all the settings needed are in there i beleive.
No problem man! That's what i do! Its understandable to be surprised with my harness when all you had seen what that other harness. Black wire sure blends in a lot better then some bright colors! Yeah the wire is very important, i use a similar wire, right on with the same size as the factory ECU harness.
Wow that exact issue happened, imagine how often it happens! I sure would hate to spend that money only to have a wire literally break off. I'm sorry that happened to you, the good thin is you don't have to worry about that again! If one of the very important signal wires break then the car will not even run!!!! That's just scary! One thing is these grey ecu plugs are VERY particular how they fit into each other, they can be installed one way and not quite connect, then remove and install again and its good to go. The connector design is just one Nissan didn't do too great. But its what we have to work with.
Oh ok, it def is COLD out. Def get some experience with EMU it will be something to value!
Good job with the whole car!
Old Jan 15, 2012 | 05:37 PM
  #82
2000_MAXIMA_KING's Avatar
Yea followed DandyMax's write up to the tee.
Thanks man!
Old Jan 15, 2012 | 08:54 PM
  #83
VQtHuRtY's Avatar
Can we see some pictures of the harness and how it wired up to the OEM ECU? After speaking to Darren, I'm considering using of the Greddy Emanage Ultimate. Give me a few weeks before I pull the trigger.
Old Jan 17, 2012 | 08:14 AM
  #84
McSteve's Avatar
I don't have fried coils but the issue used to be that if you leave your car on ON or ACC for a prolonged time voltage leaks and melts the coils. I think I have revision (G), and no issues.
Old Jan 18, 2012 | 08:46 PM
  #85
How do I check the revision of my EU? I did have the car in the ON position for a period of time when I was having issues, is there a precaution to prevent this? Especially when tuning the car will have to be in the ON position to make changes to the EU, unless I make them on the laptop, save the file, and then load them to the EU.
Old Jan 18, 2012 | 11:15 PM
  #86
McSteve's Avatar
well it's a problem in the ON position when the car is NOT running, other than that it's fine. The revision is on the circuit board written in parenthesis.
this was prevented by installing the resistors to the inside of the emanage fixed this issue i believe. Dandymax write up p.24. it says its only for CEL but i believe it fixed melted coils too.
Old Jan 19, 2012 | 06:48 AM
  #87
Well that explains how my coils fried then, the car was in the ON position and wasn't running since it wouldn't start at the time and I was measuring voltages and left it in the ON position. I may have an older circuit board.
I'll check the circuit board and wire in the resistors while I'm at it before I do anything else. I couldn't find anything about the resistors fixing this issue. Thanks for your input!
Old Jan 19, 2012 | 03:38 PM
  #88
Unklejoe's Avatar
I thought diodes were used instead of resistors.
Old Jan 19, 2012 | 03:53 PM
  #89
Flava_24/7's Avatar
Boosted Panda
Did you buy the emanage used? Reason I ask is because its been quite a few years since this was an issue requiring the resistors. I don't have any soldered in mine and Ive had my key on plenty of times for tuning.
No, its resistors.
Old Jan 19, 2012 | 06:27 PM
  #90
Yes I bought it used but the guy I bought it from had just purchased it from some shop in Cali a few months ago. I'll check the revision and just wire in the resistors to save myself the hassle. Anyone know after what revision they got the board right and fixed this issue?
Old Jan 19, 2012 | 06:36 PM
  #91
By the way these are pics of how the coils looked,
4 of the 6 coils show the symptom in the above pics which looks like they got super hot and burned up. I checked the resistances on them. The two that look normal read 1.5-1.6 kohms, two of the burned ones read 1.6-1.8 kohms, and the last two burned ones read 2.1-2.3 kohms.
The new coils read 1.8kohms for the rear and 1.5kohms for the fronts.
Old Jan 21, 2012 | 03:26 PM
  #92
Checked my board it is revision D. I switched jumper 13 to open and the fans come on but they did take a while because its cold. Since I'm using the water temp sensor instead of the knock sensor is there a disadvantage to having jumper 13 open now, which is the setting for knock sensor?
Old Jan 21, 2012 | 03:37 PM
  #93
Flava_24/7's Avatar
Boosted Panda
I thought the knock sensing feature didn't work for our setups?
I also did some searching it from what Ive read the coil pack issues was only for the Emanage blue, thus requiring diodes.
The Ultimate required resistors to eliminate the CEL for 0201 Ignition Signal Circuit
Old Jan 22, 2012 | 08:03 AM
  #94
Its not hooked up to the knock sensor its hooked up to the Water Temp but since the fans didn't come on I switched the jumper just as it says in DandyMax's Write Up.
Old Jan 22, 2012 | 10:54 AM
  #95
McSteve's Avatar
had to do the same thing
Old Jan 22, 2012 | 08:57 PM
  #96
Ok cool, I don't see it affecting anything really at all. I doubt I'll even look at water temp or knock signal anyhow. Does doing this make the water temp signal readings wrong?
Old Jan 23, 2012 | 05:48 PM
  #97
Unklejoe's Avatar
The reason the coils blow is because the ignition drivers on the EU leak small amounts of current and this keeps the transistors in the coils in the "Active Region".
Basically, the coils are supposed to be either driven ON or OFF but they never get completely shut OFF because of the leaky ignition drivers. This causes them to stay partially ON which overheats the transistors. That's what the burnt square is that is bulging out of your coils. If you chipped the burnt plastic away, you will see a transistor under there.
I run diodes in series (forward bias) with the EU ignition wires leading to the coils. The diodes prevent any current from passing through unless the voltage exceeds ~.7.
I believe my EU ignition harness may already have diode in series, so I may actually be running two diodes in series, which means that no current will flow until there is at least 1.4v across them.
Also make sure you upgrade to firmware version 2.20, as this is rumored to correct some coil melting problems.
I do not run the water temp or IAT into the Emanage. The EU actually loads these sensors down and causes some funky stuff to happen. My temp gauge would never read fully warm. The only way I would run these sensors into the EU is if they were buffered.
Just remember that the autotune (AFR Target) feature will NOT work unless you have the coolant temperature sensor hooked up. I got around this by using a resistor voltage divider circuit to produce a constant voltage which could be fed into the EU to "trick" it into thinking that the car was always warm.
Check my old thread out for some tips (credits to Dandymax for the main writeup)
http://forums.maxima.org/all-motor/6...en-review.html
Old Jan 23, 2012 | 06:03 PM
  #98
Thanks for your input Unklejoe, diodes are mainly for preventing current from flowing in the opposite direction but since the resistance of the wire is small that small leakage current wouldn't cause the .7 volts to exceed past the diode (from your findings) resulting in the leakage current never reaching the coils. Great info here, good to hear it works both theoretically and practically. Thanks!
Where exactly did you put them? I don't want to tear into my pnp harness.
My temp and iat sensors are both already hooked up to the EU, what I'm wondering is with jumper 13 set to OPEN (position for knock sensor) is that going to prevent me from being able to use the Autotune feature?
Also it says in your thread you did still burn a coil while leaving your car in the ON position while putting your seat belt on, if I'm understanding correctly this is not a long period of time. Or was it a long period of time? I see a problem with tuning if I can't leave the car in the ON position to make my adjustments, unless there is an alternative way people are doing it?
Old Jan 23, 2012 | 06:26 PM
  #99
Unklejoe's Avatar
Exactly.
Here's how I wired the diodes in. If you didn't want to cut into the PNP harness, you could install them in the engine bay, right before each individual coil.
And as far as the coolant temp reading, I'm not sure. Best thing to do would be to test via data logging and see what it shows for "Coolant temp". As long as it is above 40C, autotune should work.
Old Jan 23, 2012 | 06:33 PM
  #100
I just wanted to add that the first time the coils got burned was before the EU firmware was updated, it was running an older version. I since updated it as soon as I got the EU up and running correctly with the latest firmware and the software to match. Is the newer firmware resolve this issue?
I see in your write up Unklejoe you blame the old firmware for the frying of the coil. Is it safe to say since I updated the firmware now which was outdated at the time the coils were fried that I may have resolved the issue?
Old Jan 23, 2012 | 06:39 PM
  #101
Before the coils in the bay sounds good but iirc the harness has more then one wire I'm not sure which would be the correct wire to wire into?
Old Jan 23, 2012 | 07:15 PM
  #102
Unklejoe's Avatar
You'll need a diode for each coil. You could just be sure to not leave the key on for extended periods of time and just skip the whole diode thing though.
Some people have been running EU's for a long time with no diodes without problems.
As far as the new firmware fixing the problem, its only speculation but so far I have not burnt out another coil and it's been over a year and 20k miles.
Old Jan 23, 2012 | 07:23 PM
  #103
Flava_24/7's Avatar
Boosted Panda
Honestly, I don't know any who are using diodes in the EU, I know some had to use the resistors but with the newer firmware was supposed to fix that.
Old Jan 23, 2012 | 07:30 PM
  #104
Theory above about the diodes. Its a possible solution and the resistors is only to prevent the CEL which was fixed in the later versions of the firmware. The diodes was an idea that has been working with the EB for a while now since it had many issues of burning coils. Since the resistance of the wire is low and the leakage current is low, they are not enough to cause the .7 volts across the diode needed for it to operate, as long as the diode doesn't operate no current flows.
Old Jan 23, 2012 | 07:37 PM
  #105
Since I have the new firmware and warranty on the new coils, I'll run without the diodes or resistors for now and hopefully I won't have any issues. Going to get the WB installed this weekend hopefully get a rough N/A tune in. After, I'll reinstall the 440cc injectors and get a rough tune in.
Old Jan 23, 2012 | 07:42 PM
  #106
Flava_24/7's Avatar
Boosted Panda
Yeah, I understand that I just didn't realize it was an issue with the EU.
Old Jan 29, 2012 | 06:50 PM
  #107
Car is going back to stock, have a new project with other plans. What's for sale is here for anyone interested in parts http://forums.maxima.org/general-max...s-95-03-a.html
It was good while it lasted, sucks that I didn't get to install the turbo and see what the car can do before this happened. I'm not going to have room for the car so it must go. I'll keep everyone posted on the new project and I'm predicting when most of you see it, you'll understand
Old Jan 29, 2012 | 10:49 PM
  #108
Quickywd01's Avatar
You must've gotten a GTR.
Old Jan 31, 2012 | 08:35 AM
  #109
Yea right
Nope, a Z32 TT
Old Jan 31, 2012 | 08:44 AM
  #110
nismomaxct's Avatar
Yea right
Nope, a Z32 TT
I guess this makes it ok that you are abandoning your project. lol.
Old Jan 31, 2012 | 09:56 AM
  #111
Quickywd01's Avatar
I saw a GTR in town today. GL I heard those things make good power on stock internals too.
Old Jan 31, 2012 | 10:32 AM
  #112
t6378tp's Avatar
Turbo 3.5
Good luck hope you never have to replace anything
Old Jan 31, 2012 | 10:52 AM
  #113
VQtHuRtY's Avatar
Werd. I worked on 3 different 300ZX. They are a FEMALE DOG! Good luck.
Old Jan 31, 2012 | 11:24 AM
  #114
Well I wish I could keep both projects but that is not feasible by any means right now, so I had to choose one.
Thanks.
That's why its a project Thanks.
Old Mar 22, 2012 | 09:29 PM
  #115
97maximachief's Avatar
Were the injectors the problem?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
09maxshawn11
Sep 30, 2015 10:28 AM
