MAF Issues - Sputtering/Bucking
Old Mar 9, 2012 | 08:51 PM
99BlackMaxMS's Avatar
I am basically trying to figure out what my problem could be here, any help would be greatly appreciated. I have been having a hesitation/sputtering/bucking issue that has been consistent since I have gone boosted. It is not rpm or load dependent, as it happens at 1500rpms at 2% throttle and 5000rpms at WOT. And it is random, sometimes the car pulls fine but mostly it hesitates.
I've swapped 3 different MAFs that have been in working condition and fine on non-boosted cars. I never had a problem with my old MAF before going boosted either.
I'm currently running a V2 blower with a 3.25 pulley (10psi), a Cartech adjustable FMU and a Walbro 255lph fuel pump. I was AFC tuned on a dynojet when I was N/A and haven't gotten a chance to jump on the dyno to get numbers or find a better AFR (I'm running pretty rich).
I don't think its a fuel related issue, the spark plugs are one step colder NGK coppers gapped according to spec (they were replaced when I installed the supercharger) and the coils appear to be fine too.
Is it necessary to upgrade to a larger MAF (ie, Z32)? Has anyone else had these issues before?
Thanks guys,
Matt
Old Mar 9, 2012 | 10:50 PM
maxgtr2000's Avatar
KH3 by popular demand
Coilpacks? Infamous on 99s.
Old Mar 9, 2012 | 10:56 PM
What makes you think it's the MAF? It doesn't sound like that's the issue.
My guess would be coilpacks. They can look fine, even test fine but can still be bad. Being that you have a '99, that's where I would start first.
Old Mar 10, 2012 | 06:28 AM
Well the rear 3 have been changed out (as I have an 00vi swap). I could always get the front three and try swapping them, as I have never had any issues in the 75k miles i've driven the car. They all were replaced by the original owner IIRC though.
Old Mar 10, 2012 | 06:40 AM
Have you pulled your plugs just to see what they look like? What are they gapped to?
Old Mar 10, 2012 | 05:49 PM
I have not, but they were gapped to .037 IIRC less than 5k miles ago (when the supercharger was installed).
Old Mar 10, 2012 | 07:02 PM
036mtmax's Avatar
Is the car throwing a code ? 300 maybe.
Old Mar 11, 2012 | 10:09 AM
It did a long time ago, as it was misfiring very slightly and inconsistently. It went away and now the only code is a P0100 for the MAF, which won't go away.
Old Mar 11, 2012 | 10:17 AM
Hmm, Didn't know you were throwing the MAF code. Maybe it the harness/connector? Or a leak in the intake?
Old Mar 12, 2012 | 06:52 AM
Stillen Maxima's Avatar
Pay to Play
Im having the same exact issue. I belive 036mtmax is having a similiar issue as well; i put my money on my coil packs. They may look good but for sure one or two could be bad. Ive had MAF issues before and this does not feel the same. My car has been N/A, SC, turbo and now back to NA and between my last month of running it turbo and now that feeling is still there. So I know its not that MAF. Has to be the coilpacks. Replace them all is what I would advise. Check all your plugs too. Im going to throw on a new set of plugs and coils soon. Ive just been too busy at work to deal with it and havent had time.
Old Mar 19, 2012 | 06:43 PM
I am in the same boat as you, I just haven't had time between school and work to get a chance to pull the plugs/coils. Especially having a second car just makes me want to avoid the issue. I'll be swapping coils soon, I'll keep everyone posted.
Old Mar 19, 2012 | 07:58 PM
036mtmax's Avatar
^^^ Just to let you know i just got a quote from importrp which is an org sponsor on here for all 6 OEM Hitachi coils for 415 shipped which is a good deal. I think im gonna man up and do it. Good luck man let us know how it pans out.
Old Mar 20, 2012 | 07:06 AM
Pay to Play
Hahaha I hear you. I drove my 2nd car for 2 weeks to avoid doing this crap. There is just not enough time to do everything that I want to do during the day.
Old Mar 29, 2012 | 04:18 PM
I couldn't agree more. I've let the car sit for a couple of weeks now.
Just wanted to update, I picked up 6 coilpacks at the junkyard today and plan on swapping them out and seeing if my issue gets any better within the next few days. Hopefully it'll do it.
Old Mar 31, 2012 | 04:35 PM
I got a chance to test the coilpacks individually today, turns out that cylinder #4 was the one causing the hesitation/stuttering and its been running great since. Thanks for the advice guys.
Old Mar 31, 2012 | 06:09 PM
Quickywd01's Avatar
Happy endings are the best.
Mar 12, 2020 12:06 AM
-ReLLiK-
Apr 29, 2016 06:25 PM
BrandonCause
Sep 14, 2015 10:41 PM
ballerchris510
Sep 10, 2015 09:35 PM
dcardello
Sep 3, 2015 11:44 PM
