Hey guys, I have been out of the boost game for a little bit but I hope to be stepping back in soon. I want to run an intercooler on my V2 on my fourth gen. For those not familiar with my car it's a 98 5 speed with a 3.5 swap. I have a full V2 kit with all of the supporting mods, I would just like to run an intercooler when I put the kit back on. What size intercooler are you guys running, and are you happy with the results? Where is the best place to buy an intercooler and the piping? Any recomended piping kits? I will be running my 3.125 pulley initially and my goal is to make 400+ hp. Thanks for any help/advice.
been a long time since mine was installed. I bought an inter cooler and piping off eBay form user cxracing. Cant remember the size but its huge. Its not bad in terms of efficiency because the EU and boost sensor I see about 11-12psi at full boost. Got the 3" piping all the way too. Pulley used is the 2.87 on the V2.
Quote:
How much power does your car make? Are you a 3.0 or 3.5? Why did you go with 3" instead of 2.5" (just curious not saying you did something wrong)? What else did you need to buy other than the ebay "kit"?Originally Posted by maxima92se
looks like 96sleeper was running 3" piping as well, and my set up is very similar to his old set up....hmmmm
http://forums.maxima.org/dyno-discus...hp-368-tq.html
having seen different setups. if you manage to keep the 3" piping relatively easy to run, it wont hurt. For your goals, 2.5" is easier to run and will not hold you back. you could always do a 2.5-3" transition under the driver side fender to keep the pipe going upto the tb clean looking and 3" 400 should be easy to make, im curious to the tq and power curve.
Im using a 12x30x3 Delta Fin type purchased off Ebay, with all 3" piping. I bought a universal pipe kit off ebay with a CAI kit and just cut the pipes to fit how I wanted.
I bought my couplers from http://www.atpturbo.com/mm5/merchant...gory_Code=SILB
Im real happy with my setup, I only lost about 1-1.5 psi which I feel is pretty good considering how large the IC is.
here is a bar and plate set up similar to what you are talking aboutOriginally Posted by Flava_24/7
Im using a 12x30x3 Delta Fin type purchased off Ebay, with all 3" piping. I bought a universal pipe kit off ebay with a CAI kit and just cut the pipes to fit how I wanted.I bought my couplers from http://www.atpturbo.com/mm5/merchant...gory_Code=SILB
http://www.ebay.com/itm/Universal-Bl...32355f&vxp=mtr
also I searched for delta fin intercoolers in the size you reference and it seems that 31x12x3 is a popular size....is that what you have?
http://www.ebay.com/itm/DSM-ECLIPSE-...bcf241&vxp=mtr
*Edit*
One other thing. I don't have my parts in front of me so this may be a stupid question, but I have a Vortech BOV to go with my set up. What style flange does it use? I know it's not the same as my HKS SSQV, is it a standard two bolt like this
http://www.ebay.com/itm/Polished-3-A...40664c&vxp=mtr
Quote:
http://www.frozenboost.com/index.php...8d471f9c526e96
I am not familiar with air to water set ups. Thanks for the links though.Originally Posted by Quickywd01
http://www.frozenboost.com/index.php?cPath=216http://www.frozenboost.com/index.php...8d471f9c526e96
Quote:
I don't care either way really....I would like to keep them but I don't want to have some sort of crazy pipe routing just to keep the fogs. I'm all ears if you have a good suggestion on how to keep them eaisly.Originally Posted by MaximaSpd85
Are you going to attempt to keep your fogs or are you prepared to just loose then?
Quote:
Then I guess I shouldn't mention using your a/c for your intercooler. I know you want a basic front mount intercooler but I couldn't help myself.Originally Posted by cardana24
*Edit*
Your correct, it is 31x12x3Originally Posted by cardana24
here is a bar and plate set up similar to what you are talking abouthttp://www.ebay.com/itm/Universal-Bl...32355f&vxp=mtr
*Edit*
The flange depends on the BOV being used. I have the Vortech Mondo and its shaped just like the base of the BOV, it has to be welded on.
This is what mine looks like,
Flange for the Vortech Maxflow race,
Quote:
Nope, i was hoping you had an idea Originally Posted by cardana24
. I kinda refuse to lose my fogs which is one thing that holds me back from an ic setup. Keeping them would probably require a bunch of crazy bends, like you said, just to get to the inlet side. But im all ears too.
keeping the fogs is simple with 2.5 pipes, theres a triangular section on the frame on each side of the radiator which has enough room to drill out a 2.5 inch hole.you can then weld 2.5 inc mild steel sections to incorporate the section of pipe to the frame and use couplers on both sides, or just run the 2.5 piping through it if you want to stick to aluminum. one side comes up right near the lower rad hose, the other on the other side pretty clear of everything. you can fit a huge cooler and still keep the fogs.
Quote:
I'll take a look at that, thanks.Originally Posted by aic96max
Quote:
I think its really on ones preference. From what Ive read the Delta fin is lighter, and less restrictive allowing more air to pass through it and the bar and plate is more effecient at cooling but heavier due to more material used to make them.Originally Posted by cardana24
is there any reason to choose delta fin over bar and plate for our applications?
Quote:
http://www.ebay.com/itm/Intercooler-...item2564eb0340
Nope, but thats a really good deal. The T clamps are included and the couplers are of good quality, not the rubber pieces of crap. Thats easily 60.00+ dollars right there.Originally Posted by cardana24
is the the one you got flava??http://www.ebay.com/itm/Intercooler-...item2564eb0340
Quote:
Such a nice front end!!!!! And I hate the 95-96 bumper.Originally Posted by aic96max
I went ahead and pulled the trigger on this one. I'll try to remember to post back about how it works outOriginally Posted by cardana24
http://forums.maxima.org/6171429-post32.html
Original thread:
http://forums.maxima.org/supercharge...nt-mounts.html
If you do 90 degree elbows straight off the ic they might fit.
Original thread:
Quote:
I like how the intercooler just looks like a grille. Originally Posted by aic96max
would you think there is any advantage on forking out 300 bucks on a precision bar and plate intercooler like this
http://www.precisionturbo.net/heat-e...er---600HP/394
over the ebay ones?
over the ebay ones?
over the ebay ones?
I remember when researching an intercooler and I decided to go with a bar and plate over the tube and fin. I've had this one a few years and was going to go with a larger one, just doing some google searches it seems as though it really doesn't matter because they both do the job and both have draw backs. If you live in a consistently warm climate the tube and fin will do slightly better because heat dissipates from the intercooler itself, the bar and plate retains heat since it is more/thicker metal when it is hot. The tube and fins are thinner and are less expensive but they can be damaged by road debris easier and internally may flow less. IMO our boost levels it doesn't matter.Originally Posted by McSteve
would you think there is any advantage on forking out 300 bucks on a precision bar and plate intercooler like thishttp://www.precisionturbo.net/heat-e...er---600HP/394
over the ebay ones?
the fin density looks substantially higher on the precision ones, it probably also depends on the ebay seller. I will try to keep it 2.75" all the way through and see what it does for flow velocities...
Looks so perfect and mean. Cant wait to see what this puts out boosted man.
i dont think that at 400 whp levels, it makes such a huge difference, but, there is a huge amount of difference in fin density on true garrett/precision intercooler cores. and that is what really makes it more effective. if money is no object go with a true core, i would even consider the smaller precision/garrettt 350hp rated cooler which sometimes can be found used for cheap, over a larger, wider, ebay cooler.
you plan on getting dyno numbers before winter?
i dont think that at 400 whp levels, it makes such a huge difference, but, there is a huge amount of difference in fin density on true garrett/precision intercooler cores. and that is what really makes it more effective. if money is no object go with a true core, i would even consider the smaller precision/garrettt 350hp rated cooler which sometimes can be found used for cheap, over a larger, wider, ebay cooler. you plan on getting dyno numbers before winter?
Quote:
Yeah, Albert kinda talked me into it. I have all of the parts I just need some motivation and free timeOriginally Posted by aic96max
oops missed that you had already pulled the trigger -_-
I figured this set up is cheap enough if I need to switch to a smaller intercooler in the future I really have not lost much of anything.
