Need a little help
Old 06-05-2012, 02:14 PM
furbiss112's Avatar
Need a little help
I have two issues right now. Well, one real issue since the other is torque steer at 80 mph.
So the real issue is that right as I start to see boost, the A/F gauges leans out and car starts to buck and backfire. It is only doing this at part throttle as I ease into the pedal. Once I get over 5 ish psi it is fine and the A/F returns to normal and it pull hard to 13 psi. Car shows no codes that would cause this to happen and no misfires either. I had MAF code but cleared and I swapped out the MAF even a few coils just to be sure. Still have the same problem. Still no codes that explain this.
Also, the car was driven over 5k miles before this issue appeared.
Anyone else have any similiar issue that may be able to shed some light on this?
Details on the car
97 SE turbocharged (TO4R aka T67)
3.3L ish built motor
Built auto transmission
JWT ECU for now
Z32 MAF, 740cc injectors, walbro fuel pump
Ok, let me know what you guys got. Thanks in advance.
Ferhan
furbiss112 is offline
Old 06-07-2012, 08:27 AM
furbiss112's Avatar
So anyone have any thoughts? I would have my Nissan master tech take a look but he retired some months back.
Ferhan
Old 06-07-2012, 07:17 PM
wirelessdude04's Avatar
Could be plugs.
wirelessdude04 is offline
Old 06-07-2012, 07:25 PM
Turbo 3.5
t6378tp's Avatar
Vac leak
t6378tp is offline
Old 06-07-2012, 09:30 PM
WesCTR's Avatar
Originally Posted by t6378tp
Vac leak
makes the most sense.
WesCTR is offline
Old 06-09-2012, 07:34 AM
furbiss112's Avatar
Thanks guys. Will look into both things. Plugs have 6k miles on them and would the vaccum leak show on the vac/boost boost? My gauge stays perfectly steady.
Ferhan
Old 06-09-2012, 07:39 AM
Kevlo for President
Kevlo911's Avatar
where is the bov? before or after maf?
Kevlo911 is offline
Old 06-09-2012, 03:11 PM
furbiss112's Avatar
BOV is before the MAF.
I will hopefully taking a look at the car today.
Ferhan
Old 06-23-2012, 09:10 PM
furbiss112's Avatar
So, I worked on the car today and found what may be the issue.
I blew the custom intake manifold. I really did not expect that since I am not even running high boost. I have about a 2 inch tear in the sheetmetal so the car will be going to have a new one made from billet aluminum. Thanks for the help so far.
Ferhan
Old 06-24-2012, 04:54 AM
Turbo 3.5
t6378tp's Avatar
damn, vac leak wins
t6378tp is offline
Old 06-24-2012, 06:16 AM
KH3 by popular demand
maxgtr2000's Avatar
Man, I would think the car would run rich instead of the gauge leaning out as you described.
maxgtr2000 is offline
Old 06-24-2012, 06:31 AM
Turbo 3.5
t6378tp's Avatar
just wondering why not have the intake crack welded shut
t6378tp is offline
Old 06-24-2012, 05:26 PM
furbiss112's Avatar
I was planning on having it re-done anyways since the it was not perfect in the first place.
I think it was running lean at low boost because as the air was being forced in it would start to leak out but once the engine had enough pressure and high enough rpm the leak was not as great. But we will see once I have the new one on there.
Ferhan
