My 2013 turbo 4gen build thread
went to the track on the stock clutch hoping for atleast a high 13sec pass, BIG mistake came when with a slipping clutch and a 18.65@56mph
Not worried about stuff going into the compressor? Just don't care? Baller? Because racecar? I like it, all out performance. How do you feel driving through dust and such? Oh and btw how did you address your trans? Shift easy or did you brace it and add parr?
I don't drive on dirt roads and I have a mesh screen, never had a issue in 3yrs and neither has anyone I know. As for the trans I always keep a spare but I've learned to roll into the gas and not just smash it to the floor.
In the future I do plan on getting par 3rd and 4th gear though
Meth + LSD =
Thanks on the meth kit info. Car's not driving yet. I'll be running a water to air barrel intercooler sc not turbo. But the more the better so I'll look into the meth kit again once I'm at that point. I do have this nos wet kit I want to experiment with as well...
I don't see much expermentation documented about these kinds of things here. I am all for it. Either off the line or down the line, I want to experiment with spray. Also, it could be used as a IC sprayer if all else fails. Have you ever seen the sc cobra IC setups that use the car's a/c? Fun stuff, keep up the good work!
car back together did a quick idle vid with the 3inch exhaust
https://www.youtube.com/watch?v=cbLHQENzx2M
went to a dyno meet the following day and made 300hp on 7psi with the spark blowing out
https://www.youtube.com/watch?v=wHc7sj3uEGw
Working on it...
One day...
