My 2013 turbo 4gen build thread
Old Nov 18, 2014 | 03:56 AM
  #321
t6378tp's Avatar
Turbo 3.5
6spd axle bracket vs 5spd axle bracket
Old Nov 18, 2014 | 03:59 AM
  #322
t6378tp's Avatar
Turbo 3.5
found alot of missing info while doing this swap so I took these pics. I heard the brackets were the same which they clearly are not, which made the reason some people have issues and others don't, axles are different too.
also there is a few items and steps in the swap process that I will include as well
Old Nov 20, 2014 | 03:52 AM
  #323
t6378tp's Avatar
Turbo 3.5
when removing the 5spd shifter and linkage which had a boot to protect it the 6spd shifter is left exposed. in the pic you can see the exhaust is right below it. I was to just leave it which was a big hellz no
Old Nov 20, 2014 | 03:53 AM
  #324
t6378tp's Avatar
Turbo 3.5
so under the advice of a OG I went back to the parts car and got this, it's a cover for the 6spd shifter to protect the bottom
Old Nov 20, 2014 | 03:55 AM
  #325
t6378tp's Avatar
Turbo 3.5
did have a extra set of hands at the time so I tack welded these bolts to it
Old Nov 20, 2014 | 03:56 AM
  #326
t6378tp's Avatar
Turbo 3.5
it's a direct bolt in for a 4gen and lines up great it had a foam weather stripping on it but I use clear rtv just encase
Old Dec 14, 2014 | 06:49 AM
  #327
t6378tp's Avatar
Turbo 3.5
had to trim the rubber mounts alittle
Old Dec 14, 2014 | 06:50 AM
  #328
t6378tp's Avatar
Turbo 3.5
Old Dec 14, 2014 | 06:51 AM
  #329
t6378tp's Avatar
Turbo 3.5
shifter installed
Old Dec 14, 2014 | 06:52 AM
  #330
t6378tp's Avatar
Turbo 3.5
sneek peek
Old Dec 23, 2014 | 05:15 PM
  #331
s1mply_v's Avatar
Just caught up with your thread..
Old Dec 24, 2014 | 04:47 AM
  #332
t6378tp's Avatar
Turbo 3.5
lol, thanks
Old Dec 24, 2014 | 04:56 AM
  #333
t6378tp's Avatar
Turbo 3.5
bought this to make a hole in the firewall for the shifter cables, this was a real pain in the ballz to do while the motor is in. My car was a factory 5spd not auto so the hole ws not there
hole done and I got lucky and was able to use the factory bolt holes, fyi I'd suggest moving your ecu while doing this
Old Dec 24, 2014 | 04:58 AM
  #334
t6378tp's Avatar
Turbo 3.5
interior all back together
Old Dec 31, 2014 | 11:08 AM
  #335
deloa84's Avatar
Hows the shifter with the new 6speed? Just curious as I am about to do this soon enough and I have an auto trim.
Old Jan 1, 2015 | 06:35 AM
  #336
t6378tp's Avatar
Turbo 3.5
shifter is fine, it doesn't have same connect feel as rods but whatever
Old Jan 11, 2015 | 07:41 PM
  #337
aic96max's Avatar
what are the strength gains from the 5 spd say lsd to the 6 sp? is it just cool factor gains? or are there real usable gains from a putting power to the ground perspective?
Old Jan 12, 2015 | 06:29 AM
  #338
Crusher103's Avatar
6spds have been known to reliable hold up to 450wtq from the VQ35. They are beefier internally than the 6spd plus the have better gear ratios especially in the case of the SpecV with the 4.1 FD. Also better clutch options as we can use 350Z clutches with the 6spd. For a boosted maxima in the mid to low 400 this trans should be pretty stout.
Now idiots like aackshun broke his in an NA VQ30 so they are not bulletproof.
Old Jan 12, 2015 | 09:11 PM
  #339
t6378tp's Avatar
Turbo 3.5
shifter cables don't have the same connected feel as rods but I have some redlion shifter cable bushes so I hope that helps
Old Jan 12, 2015 | 09:14 PM
  #340
t6378tp's Avatar
Turbo 3.5
the 6spd trans is newer, easier to find with low mileage, stronger than a 5spd but most have 3rd crunch issues. for boost and racing I like the 5spd better but the 5spd breaks so 6spd it is. I'm still getting used to gearing of the 6spd and even with a 7k rev limiter find myself bouncing off the limiter
Old Jan 13, 2015 | 05:24 AM
  #341
Crusher103's Avatar
Which 6spd did you get? The +04 out of the specVs and maximas usually are best suited for NA VQ35s. The 02-03 maxima 6spds have the long 3.8FD which would be best for boost. Please dont tell me its an 02-03 specV trans because yea you will spin, A LOT with that. That trans would be great for a bolt on NA VQ30 nice short gears but i cannot imagine it with boost.
Old Jan 13, 2015 | 04:41 PM
  #342
t6378tp's Avatar
Turbo 3.5
I got a 6spd from a 5.5gen
Old Jan 15, 2015 | 03:58 AM
  #343
t6378tp's Avatar
Turbo 3.5
old 5spd trans is out and small compared to the 6spd, time to clean up the 6spd alittle too
Old Jan 15, 2015 | 04:02 AM
  #344
t6378tp's Avatar
Turbo 3.5
started cleaning the 6spd
Old Jan 15, 2015 | 04:03 AM
  #345
t6378tp's Avatar
Turbo 3.5
started cutting the 5spd body mount off
Old Jan 15, 2015 | 04:05 AM
  #346
t6378tp's Avatar
Turbo 3.5
notched the inner fender to make the install easier
Old Feb 15, 2015 | 06:24 AM
  #347
t6378tp's Avatar
Turbo 3.5
used a empty 6spd trans to locate the trans mount and weld it on
Old Feb 15, 2015 | 06:25 AM
  #348
t6378tp's Avatar
Turbo 3.5
filled the mount with window weld and burned it in
Old Feb 15, 2015 | 06:28 AM
  #349
t6378tp's Avatar
Turbo 3.5
had to grind the engine the ground to clear the ss clutch line on the slave
Old Feb 15, 2015 | 06:29 AM
  #350
t6378tp's Avatar
Turbo 3.5
also had to remove the abs bracket to clear the shifter cable linkage
Old Feb 15, 2015 | 06:32 AM
  #351
t6378tp's Avatar
Turbo 3.5
soooooooo it looks like my turbo kit will not clear the starter, I'll deal with that at another time
Old Feb 15, 2015 | 06:34 AM
  #352
t6378tp's Avatar
Turbo 3.5
now it's time to pull it all back apart so I can clean things up alittle and install the clutch an flywheel
Old Mar 4, 2015 | 10:41 AM
  #353
deloa84's Avatar
Forgot to ask what boost controller are you running?
Old Mar 7, 2015 | 06:40 AM
  #354
t6378tp's Avatar
Turbo 3.5
just a 20 dollar dsm mbc
Old Mar 16, 2015 | 06:38 PM
  #355
timmay5835's Avatar
Nice build. Great work.
Old Mar 22, 2015 | 05:42 AM
  #356
t6378tp's Avatar
Turbo 3.5
new CC stage 4 unsprung clutch
Old Mar 22, 2015 | 05:43 AM
  #357
t6378tp's Avatar
Turbo 3.5
clutch and 6spd swap flywheel installed now time to make a new turbo kit
Old Apr 3, 2015 | 09:21 PM
  #358
t6378tp's Avatar
Turbo 3.5
so the old turbo kit did not clear the 6spd starter and it was easier to just make a new than than mod the old one so I sold it
Old Apr 3, 2015 | 09:22 PM
  #359
t6378tp's Avatar
Turbo 3.5
going to try something new this time, here's alittle sneek peek
Old Apr 11, 2015 | 01:21 PM
  #360
Quickywd01's Avatar
Reverse header setup is going to be amazing!!!
