NisTune
Old Nov 16, 2014 | 04:46 PM
  #201
maxprivate's Avatar
Black Lion
OH and I spoke to JSutter who believes I can use the actual EGR solenoid for the MEVI. Same thing right?
i would just remove the ground signal from the Egr solenoid coming from the ECU and bring that to a different solenoid. As Mat said, you need to disable the EGR in the Nistune software and use the ground signal on the EGR solenoid to trigger the mevi solenoid for vacuum. BTW you need a 3 port solenoid I believe. I have to look at mine and confirm but I ordered it from Nissan and it's also in the Mevi write up if I'm not mistaken.
Now this makes sense as Mat didn't explain it to me in that much detail. You bring 12v to the positive side of the solenoid and the ground is taken from the EGR solenoid ( your trigger output from Nistune at a set RPM) and EGR disbaled in Nistune. When it's time for emissions if needed switch it back to stock and enable EGR in software.
Old Nov 16, 2014 | 05:05 PM
  #202
I have the GM one I think. Not sure if it works though.
Old Nov 16, 2014 | 05:16 PM
  #203
maxprivate's Avatar
Black Lion
Not sure about the GM one .. Can only tell you from what I used. I used the 3 port Nissan solenoid and It worked perfect with emanage ultimate trigger output.
Old Nov 16, 2014 | 06:00 PM
  #204
Not sure about the GM one.. Can only tell you from what I used. I used the 3 port Nissan solenoid and It worked perfect with emanage ultimate trigger output.
I have a Delco Remy DR152 2250-1 3-port boost solenoid (aka "GM boost solenoid") and a vac canister that I have no idea what it is lol
Vac canister:
Old Nov 16, 2014 | 06:04 PM
  #205
I was thinking about using the EGR solenoid by cutting the power wire and hooking that to a 12v ignition source.
Old Nov 16, 2014 | 06:42 PM
  #206
Has anyone else had this done? I'm confused as to how I'd wire this up.
This is the info I got from Matt..
"The MEVI requires a VCT controller of sorts to activate the solenoid to control the valve timing. I identified that the only available output would be the one controlling the EGR solenoid. The EGR output is negative controlled. You change the wiring from the EGR to the VCT solenoid. The other end of the VCT solenoid is ignition switched 12V power. This activates the VCT solenoid when in certain load/rpm ranges.
EGR solenoid will no longer function once VCT is enabled. In the software you disable ‘EGR’ to use the output for VCT. You need to disconnect EGR solenoid and wire to VCT. Do not splice and run two solenoids from the single driver output! It would blow up the driver due to excessive current load.
If you need EGR for emissions later on, then swap the wire back and reenable the ‘EGR’ tickbox in the ‘feedback flags’ parameter in the software."
My ECU should be there tomorrow
I'm not understanding it in words. I need to see all this mumbo jumbo in an actual diagram to make sense of it.
Old Nov 16, 2014 | 07:29 PM
  #207
^ That. And this? (Not 100% sure).
Old Nov 17, 2014 | 05:40 AM
  #208
Crusher103's Avatar
i might be jumping on the Nistune boat by the end of this week, im also interested in this EGR thing for a VI.
Old Nov 17, 2014 | 07:33 AM
  #209
Help me figure this out ya bish.
EDIT: That EGR solenoid diagram I wrote up (not from Matt).
Old Nov 17, 2014 | 04:06 PM
  #210
t6378tp's Avatar
Turbo 3.5
damn that's hot basically your using the oem niod in place of the gm niod
Old Nov 17, 2014 | 05:12 PM
  #211
That's exactly what I'm trying to do. Just need to figure out how the vac lines will go.
Old Nov 18, 2014 | 06:47 PM
  #212
Andy at AutoVaughn Performance got my ECU
The anticipation is killing me.
Old Nov 19, 2014 | 04:41 PM
  #213
t6378tp's Avatar
Turbo 3.5
no different from setting it up with a gm niod you just need to swap the ports cause the gm niod is no vs nc where as the nissan niod is nc vs no or vise versa
Old Nov 19, 2014 | 05:57 PM
  #214
Is my diagram right then?
Old Nov 20, 2014 | 03:45 AM
  #215
t6378tp's Avatar
Turbo 3.5
did see it but I used the writeup on vqpower also make sure your vac can has a built in check or run one inline with it
Old Nov 20, 2014 | 03:46 AM
  #216
t6378tp's Avatar
Turbo 3.5
motor to vac can, vac can to niod, niod to mevi are, niod wired to a switched 12v source through a relay
litch
123
Jan 4, 2024 07:01 PM
95maxrider
Dyno Discussion and Slips
19
Aug 15, 2018 10:43 AM
schmellyfart
18
Feb 24, 2015 02:37 PM
crewchief264
Jan 23, 2015 09:19 PM
