Boost Problem
Old Sep 17, 2013 | 07:25 AM
olivas's Avatar
Boost Problem
Alright I have done a search to see if anyone has had this problem and didn't really find anything. I just supercharged my max about a month a go, I am running a 10 psi pulley, with 2.5" IC piping, 00IV, 600 DW injectors, aeromotive fuel regulator, Warbol 255 fuel pump, Z32 maf and I tuned it with nistune. My problem is that I can't seem to make much boost, I boost leaked check it, fixed that leak (turned out the lid of the maf was lifting) and I got it up to 5 psi close to redline, I know that because I'm at altitude (6,500ft) i wont make 10 psi, but I feel like I should be making more then 5psi. Any help or guidance is much appreciated.
Old Sep 18, 2013 | 07:58 AM
Max streets's Avatar
Did u do an air leak test,u really wont know if leaking or not cause very hard to tell if air is leaking and is bypass valve set right.
Old Sep 21, 2013 | 08:33 AM
TunerMaxima3000's Avatar
What is your redline? What trim is the supercharger? Have you set the Bypass valve? Do you have an intercooler? Do you have any intake or exhaust modifications, or cams, etc?
Old Oct 2, 2013 | 08:49 AM
TurboA32's Avatar
Could be leaking from manifold somewhere. Do you clamps on your vacuum lines ect....?
James92SE
142
Jan 2, 2024 09:23 AM
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
homewrecker
Sep 24, 2015 07:01 PM
hozay99
Sep 19, 2015 10:20 PM
