Safest way to supercharge my 00'
Quick question.... i dont really have the money to upgrade my car right now.....if i could just slap a supercharger on what would i be looking at to replace like what would be the minimum parts used to boost it, i have read about the oil pump and ring lands, what else??
Have you read Stillen's install instructions? No special tasks required like upgraded oil pump etc. The only basic upgrades you should do are a tranny cooler if you're auto, and a valve body upgrade. And of course, all maintenance up to date and be sure you have a healthy engine to start with (compression test and /or leak down test)
http://www.vqpower.com/v3/content/su...0-2001-maximas
have a healthy engine and at 6psi with supporting mods like a y-pipe back exhaust and some basic air/fuel controller tuning u can make VERY reliable power.
there's still a dude from british colombia selling a supercharging kit (all stillen) for like $1500
I'm hitting the track pimpin' asap....
haha my bad wizard...
can somone link me up to the info i need ? just lay it out for me?? just the best info u could link me to..... im talkin
cams & valves
piston & rods & rings (theres a upgrade kit)
clutch & flywheel (lookin at fidanza and exedy/stage 3 xtr for same)
http://www.ebay.ca/sch/i.html?_from=...lutch&_sacat=0
fuel pump (walbro 255)
fuel management
fuel rail & injectors, coil packs & plugs
thick head gasket
valve body
engine mounts
drive line
differential?? saw one from quaife they sell just the differential?? (http://shop.quaife.co.uk/nissan-maxima-quaife-atb-helical-lsd-differential)
gear set, shaft transmission (big one) quaife?? or par
transgo kit??
Just what u guys think i should be going with?? im a total newb to all this so hearing it from educated peeps is better for me
its a 2000 se , hook me up with the info!!!! lol
im jotting down info as i read.....
cams & valves
fuel management
thick head gasket
valve body
engine mounts
drive line
transgo kit??
is that still up for sale, can u link
KabirUTA13
19
Oct 17, 2015 02:15 AM
