*Will this rim/tire combo be a problem???...*
Old Jul 23, 2003 | 09:19 AM
clipse's Avatar
I plan on purchasing the following("maybe"):
-18x8.5 rims
-5x114.3 bolt pattern
-35mm offset
-225/40/18 tires
I just wanted to know if I will run into problems running this kind of wheel/tire combo on my car. (ex: rubbing against the fenders etc.) Any help will be appreciated.
*NOTE: My car is currently lowered on KYB AGX's/PROGRESS Sport Springs on stock rims/tires.*
Old Jul 23, 2003 | 11:31 AM
2k2nyc's Avatar
That will be fine. I would actually go with a bit more tire than that, 245/40 or 235/40
Old Jul 23, 2003 | 01:32 PM
asu174's Avatar
Clay Aiken has fancy genitals
Definitely get wider tires. Those are too skinny. 245/40 will be perfect.
Old Jul 23, 2003 | 09:18 PM
clipse's Avatar
2k2nyc/asu174,Thanks for the info. So I should have no problems whatsoever with this tire/wheel combo on my car??? BTW,Yeah I know the 225/40/18 tires sidewall etc.is skinny. But the person selling them already has that size mounted on the rims But I do plan on upgrading the tires to 245/40 or 235/40 if I do purchase this tire/wheel combo from him.
Old Jul 24, 2003 | 06:05 AM
2k2nyc's Avatar
No problems whatsoever.
Old Jul 24, 2003 | 07:43 AM
clipse's Avatar
Thanks...
Old Jul 24, 2003 | 06:27 PM
ch13f's Avatar
225.. thats kinda thin.. I've got 235s on my 8" wide rims.
Old Jul 27, 2003 | 10:08 PM
clipse's Avatar
*2nd Choice* I plan on purchasing the following("maybe"):
-18x7.5 rims
-45mm offset
-235/40/18 tires
Old Jul 28, 2003 | 08:17 AM
2k2nyc's Avatar
Still no problem.
Old Jul 28, 2003 | 08:19 AM
2k2nyc's Avatar
I forgot one thing, they're still gonna look tucked with that offset.
Old Jul 28, 2003 | 08:29 AM
clipse's Avatar
Still no problem.....I forgot one thing, they're still gonna look tucked with that offset.
2k2nyc,With the rims being "tucked",Is that a bad thing??? Here is a pic of the rims I "might" plan on getting:
Nakayama 6 Speeds
Old Jul 28, 2003 | 08:35 AM
2k2nyc's Avatar
I cant see the pic. Being tucked is not a bad thing, its just personal preferance on the way it looks.
Old Jul 28, 2003 | 08:38 AM
clipse's Avatar
"Sorry"....
Nakayama 6 Speeds,The only avaiable size in 18's is 18x7.5 with a 45mm offset. So this would not pose a problem even with my car being lowered???
Old Jul 28, 2003 | 08:48 AM
2k2nyc's Avatar
No, no problem at all. Those wheels are nice, good choice. If you look at the rear wheel, you can see what I mean by tucked, it sits far in from the body, but you can always add some H&R spacers if you want it to be flush with the fender.
Old Jul 28, 2003 | 09:39 AM
clipse's Avatar
2k2nyc,Thanks for the info. I have one last question. Will running a 235/40/18 tire be sufficent??? I was planning on 245/40/18 also(thats if it's within spec) I didn't want a skinny sidewall.
Old Jul 28, 2003 | 10:39 AM
2k2nyc's Avatar
235/40 fits fine, but it does have a small sidewall. You should go with 235/45. Your speedo is gonna be off by 1.8% (ex. you'll be driving at 61 mph when your speedo reads 60). Im currently running 245/45/18 and my speedo is off by 3.2%, its does not bother me at all. The 245/40 series tire is not in spec for a 7.5 width, if you do want a 245 tire, then you'll have to go w/ 245/45 like me. The sidewall is about 1/10th of an inch less than stock. I didn't want to go any lower b/c the streets in NY blow. I say go with the 235/45, thats the profile the new 5 series BMWs have; you'll have a nice profile + some comfort. You can use this link to compare tires and sidewalls: http://www.miata.net/garage/tirecalc.html
Old Jul 28, 2003 | 06:34 PM
clipse's Avatar
2k2nyc,Thanks for the help and info. I appreciate it.
Old Jul 28, 2003 | 07:41 PM
2k2nyc's Avatar
No problem
Old Jul 30, 2003 | 07:50 PM
redstradic's Avatar
so the smaller the offset the less the wheel will be tucked in from the body? is that correct. i was looking at a 38mm. the closer to 30, the more it will be flush with the body. i was looking at a 18x8.5 with the 38mm offset. will that be tucked. thanks
Old Jul 30, 2003 | 08:47 PM
asu174's Avatar
See homepage. I have 18x8.5" with a 38mm offset.
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
