Someone explain wheel offset to me please.
Old Sep 9, 2003 | 05:02 PM
LithiuMax
What do the different millimeter offset numbers mean? Is it possible to make the stock 03 SE rims move more outwards, so they don't sit "inside"
of the car so much? I am pretty sure that is what offset is, but I don't know the details..
Old Sep 9, 2003 | 05:25 PM
LithiuMax
Anyone know?
Old Sep 9, 2003 | 05:40 PM
maxima42's Avatar
Wheel offset is the measurement in millimeters that the lug holes are from the center of the width of the wheeel.
Spacers are available to change the offset, try Apexi
Old Sep 9, 2003 | 09:34 PM
Bman's Avatar
You want to move your stock rims further out for some reason? Why? I wouldn't do this because you'll get more steering kickback and if you go too far you might get an interference problem....
Old Sep 10, 2003 | 04:48 AM
MaxSE03's Avatar
Here is a quick explanation from the tirerack:
__________________________________________________ _____
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
__________________________________________________ ________
Here is a great calculator for determining what offset will work on your car:
http://toy4two.home.mindspring.com/offset.html
RinconI30
Jun 11, 2016 08:25 PM
Excalibur23
Oct 13, 2015 04:33 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
jfl330
Sep 4, 2015 01:44 PM
