Planning to buy Sumitomo HTR+ tires for my Max, anybody has them?
Old Dec 3, 2003 | 10:59 AM
Dany's Avatar
I am planning to get them in 235/45R17 size. They have pretty good rating on Tirerack.
Anybody has them and how do you like them? Rain, snow, dry handling?
Thanks.
Old Dec 3, 2003 | 11:30 AM
max bear's Avatar
After a long and extensive research i decided to buy the Sumitomo HTR+ about a year ago. So far i have no complaints, i immediately notice a huge improvement in wet traction. The tires are quiet and ride very well. I am very pleased with them, as far as i am concerned they are just as good as much higher priced tires.
Old Dec 3, 2003 | 12:04 PM
nhokt's Avatar
Thanks.
I was in a similar dilema yesterday, I ended up going with the ContiExtremeContacts over the HTR+, snow performance is very important to me and I have always used Continental tires on my bike...
Old Dec 3, 2003 | 12:56 PM
Dany's Avatar
I was actually deciding between ContiExtremeContact and HTR+, Contis are a bit
more expensive compared to HTR+.
i think I am set on HTR+.
Thanks for the input guys.
Old Dec 3, 2003 | 01:15 PM
soundmike's Avatar
Very sound, Mike
I have the HTR+ myself - actually got it used from a friend who had it and rims on his (now sold) Max.
It's a vast improvement over the RE92's.
Check out my short review of it here:
http://forums.maxima.org/showthread....ghlight=htr%2B
Old Dec 3, 2003 | 02:14 PM
ghostrider17's Avatar
Maxbear -- how many miles have you racked-up?
And also -- do you think the sidewalls on the SUMIs are softer than the RE92's???
I'm dang close to buying these, and the only that scares me is that some guys are saying the SUMIs are not as stiff in the sides, and don't handle as well in the sweepers.
Please let me know....
thanks,
gr
Old Dec 3, 2003 | 02:31 PM
240se's Avatar
Thanks.
The Tire Rack has them in 215/50/17 for $74 each! This size is a better fit for the stock 7" rim. I have 4 in my garage that are going on my Max this weekend.
Bryan
Old Dec 3, 2003 | 03:27 PM
Dany's Avatar
Bryan
Yeah I was thinking about that size too, but if you look at it has load rating of 91 and
our stock tires have load rating of 93. Now 235/45 size has load rating of 93 but it
is a little bit wide for our rims. Number of people run 235/45 on stock rims and seem
to be fine.
Old Dec 3, 2003 | 04:47 PM
soundmike's Avatar
Very sound, Mike
As far as load ratings go, between the size i got and the OEM Potenza's - it comes out to approximately 600lbs. of weight distributed equally over four corners.
I constantly have a full load on the car and i have had no issues whatsoever. Additionally, i don't have it with me right now but the 16" on previous year GXE's were load rated at 91 - so there's really not much of a problem at all.
Btw, i've had my HTR+'s for more than 8k miles and the previous owner had it on for about that long as well.
With regards to softer sidewalls, the Max takes turns (including sweeping curves) far better with the HTR+ than it ever did with the Potenza at any tire pressure.
Old Dec 3, 2003 | 04:58 PM
njmaxseltd's Avatar
I got a set of HTR+ this past spring. Very smooth and quiet tire with nice handling and great wet weather traction.
A great buy for the price, and they look hot too.
Old Dec 3, 2003 | 06:53 PM
240se's Avatar
to be fine.
The Tire Rack said that the 215/50/17 with the 91 load rating were OK if I ran 36psi or more in them insted of the Nissan recomended 32psi for the 225/50/17. I'm running 40psi in my RE92s because the sidewalls are so soft.
Old Dec 5, 2003 | 04:51 PM
sean05's Avatar
There great tires. I just got them put on a while back. First i started to hear this loud sound but i eventually found that my right front wheel bearing was bad!! So after i had it replaced it sound soo quiet and smooth. The hold up great in the rain. I would recommend them.
02nissmax
Sep 5, 2015 01:50 PM
MplsMadMan
Sep 4, 2015 02:23 PM
FlaMark
25
Aug 28, 2015 10:15 AM
twotonezed
Aug 16, 2015 11:41 AM
