Why do my tires pull the steering wheel???
Does tramlining increase with speed rating????
I have a set of Z-rated Falkens 235/45/17R that pull my steering wheel in the direction of the grooves and dips of the road. Is this because these tires are high performance? I need a new set and dont want to buy tires that perform the same way. Can someone explain this...
Did you just have the 15" stockers on your car before this? If so, then I am pretty sure this is to be expected to some degree. The difference is that you had tall, poofy sidewalls on your old tires, but now have short, stiff, high performance sidewalls on your 17's. The tires are also wider. The effect of pulling the steering wheel which ever direction the ruts and bumps in the road go is called "tramlining" (lines and ruts usually) and steering kickback (sharp bumps usually).
Tramlining is a common issue with tires. It mostly depends on design of the thread. Some tires are worse than the others. Do your research and read reviews. When designing the thread, tire manfacturers have to make trade-offs between wet/dry performance, rolling resistanse, speed rating, wearability, etc, tramlining included. You can't have a perfect tire, so decide what's most important to you.
Does tramlining increase with speed ratings????
From what I've read it seems that tramlining is worse with tires that have a tread design that incorporates more continuous, uninterrupted ribs, like some of the touring high performance tires. (Recently one of those Continental tire models comes to mind.) Also, stiffer sidewalls seem to make a difference because it's less compliant, so to a certain extent speed rating has a little to do with it because higher speed rated tires tend to be more reinforced all around. You could maybe try a softer more comfort oriented tire and see if that helps, but I have no idea how much of a difference it would make. Maybe try asking for advice and some suggestions from the experts at Tires.com or the Tirerack?
I recently had my tires mounted, balanced, and an alignment at town fair tire. I bought falken ziex 512 215/60/15 from discount tires. I took it on the highway and the car still pulls slightly to the right when I let go of the wheel. It's pretty annoying. Could this be a tramlining or the alignment wasn't done right? I want to bring it back to town fair tires to get it aligned again. What should I ask them/ tell them?
The tramlining effect now has greatly diminished as the tires have worn down.
So...would I buy these tires again?? They have tremendous dry and wet grip and as someone else on the org has said and I quote "shed water like moses", but my first experience ever with a tire tramlining will lead me to go with another tire when these wear out. Who knows, I may eventually come back to this tire after I try others simply because it has tremendous grip but I am willing to give up a little grip for no tramlining whatsoever.... and I do mean a little..
Ok so I set the pressure of my tires to 33 psi front and rear yesterday. The car still pulls to the right. So today I went to get a re-alignment. I was told that my tire pressures were all different. hmmm??? Strange because I just checked them a day before. Anyways he inflates it all to the same psi and the alignment is in factory specs but the car still pulls. He said something about only the toe and be adjusted. What else can cause this pulling? Maybe the tire was inproperly installed and leaking air?
Tire
Where there are grooves on the road my Kumhos are the worst. Mad pullage from side to side. My brother with all season Sumitomos HTR+ seems to never experiance this, so that's what I'll go with next time I'm buying tires.
trasmadean
02-01-2017 08:20 PM
vingodine
45
05-21-2016 12:46 PM
Maxima_Joe
11-25-2015 08:19 AM
02nissmax
09-05-2015 01:50 PM
