Max with G35 18" wheels and drop
Originally Posted by jattmax
LOL
Some of the problems you will see using the G35 wheels on the max is 1. you can't rotate your tires unless all the wheels are the same width. 2. tires stick out past the fender well, think of all the nice paint chips. I guess you can always go to a 4X4 shop and get some 3 inch fender flares?
Originally Posted by 808MAX-SPEC
G35 Coupe 18" wheels and tires
18x8 all around
35mm offset
Front tires: 225/45/18
Rear tires: 245/45/18
I have a friend who also has a AE and he put the coupe wheels on his car. Looks sweet. He jus has to be careful going over large bumps because the the rears are 245s and they just clear. If and when i do get my set i plan to put 235s all around, prob S-03. Go on ebay and bid for the next available set. Caution: Everytime there is a set available one or two wheels are scratched. Let me know if yoou decide to get them.
Forgot to add the my friend has H&R and Koni's.
Originally Posted by housecor
Curious - Is anyone on the org acutally running G35 18's? I chopped a shot with a little drop to see how it looks. Impressions?
good idea..... But it might be cheaper to buy aftermarket rims... plus are those stock G35 rims heavy
Wow, I bet the Z wheels look great! Any pics?
IMO i think the G35 wheels looks a lot better than this 350Z wheel...
Originally Posted by 2K3MAXX
http://www.cardomain.com/id/mclee45
I'd be more interested in the Brembo brake upgrade than the wheels. Since our rotors are only 10.7 inches in diameter (smaller than a civic) hence the rotors warping all the time. I need more stopping power.
A guy named Randall emailed me a couple shots of his Max w/ G35 18's. Looks pretty slick:
they look GREAT on 5th gens!
now can we settle the fitment issue?
I too heard they rub in the rear, especially if lowered..
I've seen a 5th gen with Z touring 18's and the rear rubs, especially on a lowered car... the tires are too wide.. might work with a slimmer tire but still, it's going to be close..
but the g35c wheels are
and look amazing on 5th gens
hopefully they go down in value ..
and look amazing on 5th genshopefully they go down in value ..
1. Rotate tires at will!
2. No rubbing (hopefully)
If anyone with G35 18"s is running a thinner tire than 245 and still experiencing rubbing, please let me know.
As mentioned earlier, the G35 18's are all the same size. 18x8" front and rear. Everyone I've seen having rubbing issues is running larger tires in the rear (245's). If/when I get these, I'm running 225/235 all around. This way:
Just won g35c wheels off of ebay. Gonna get the S-03s, 235-40-18. May not be for awhile though. Funds got diverted elsewhere. I have a friend who has SSR Gt1 at 18X8 w/the S-03s i want to get. The only trick is the offset. I feel confident that the wheels should fit. My friend Randall has proven that, so I won't worry about it. Good luck getting your wheels!
Yo housecor-
Originally Posted by Jeff92se
How much do the 18" G35 rims weigh? I know they are al 18x8 but don't the frt/rear sitll have diff offsets?
dank4us
34
Jun 10, 2024 03:45 AM
02nissmax
Sep 5, 2015 01:50 PM
Maxima_Joe
Aug 27, 2015 12:01 AM
BobMax
Aug 15, 2015 12:35 PM
weight?
