5x115 Bolt pattern on a Maxima
Old Feb 21, 2004 | 08:01 PM
jmrussell2003's Avatar
Would 18x7 inch wheels with a 5x115 bolt pattern, 225/40/18 fit on a 4th gen Maxima?
Old Feb 21, 2004 | 08:09 PM
Phatmax98's Avatar
I don't think so..our bolt pattern is 5x114.3
Old Feb 21, 2004 | 08:11 PM
WHOS UR DADDY's Avatar
depends on the wheels and the offset
Old Feb 21, 2004 | 08:33 PM
With 40mm offset
Old Feb 21, 2004 | 10:28 PM
limsandy's Avatar
40mm offset will fit fine, no problem. However, 7" wide wheels are too thin, get at least 8".
~limsandy
Old Feb 21, 2004 | 11:20 PM
bigx323's Avatar
its says 40 for the thickness so its not thin at all.
but 225 are 2 small get like 230's
Old Feb 21, 2004 | 11:23 PM
maxspeed96CT's Avatar
The original VQ...
40 isnt the thickness , that is the part were the wheel bolts up. 7 is the width
Old Feb 22, 2004 | 12:16 PM
Bman's Avatar
What the heck uses 5x115 anyway? I've rarely ever encountered that number.
Personally, I wouldn't use it. It sounds close, but seeing as how all the stress is riding on those studs and the holes in the wheels, I wouldn't myself....
Old Feb 22, 2004 | 01:03 PM
I had these on my Lumina, but it was totalled last month, so I was wondering if they would fit on my new maxima. I noticed the bolt pattern was close so I was just wondering. They are 18 in chromes, and I spent so much on them, and prob won't get much if I sell them. http://www.cardomain.com/memberpage/370743/2
schmellyfart
Sep 25, 2015 04:47 PM
MaxStock
Aug 12, 2015 08:33 AM
ZerotoSixty
Aug 6, 2015 04:34 AM
yat70458
Aug 3, 2015 01:16 PM
