Planning to get Sumitomo HTR+ tires for my car.
Old Mar 16, 2004 | 08:19 AM
Dany's Avatar
Hey guys I am planning to get Sumitomo HTR+ tires for my.
Anyone running them on the Max? How are these tires?
Thanks.
Old Mar 16, 2004 | 08:31 AM
NuJerseyDrive's Avatar
I've had them for over a year now. For the price their pretty d@mn good ($89.00 each at tirerack). As a matter of fact I have 2 more coming in to replace my fronts. I kinda slacked off and didn't rotate like I was supposed to so their shot. Had I stayed on top of things they would have lasted more than a year. The rears still look brand new.
Their good on dry pavement and just as good in rain. In the snow their steady as long as you maintain a responsible speed.
So far I've had the OEM's and Falken FK451's. The Sumi's outperforms both.
I'm sure there are better tires out there but if you don't want to spend a grip of dough then you can't really go wrong with the Sumi's.
Just make sure your on top of rotating them as well as keeping track of the air pressure.
Old Mar 16, 2004 | 08:39 AM
Dany's Avatar
So far I've had the OEM's :rolleyes: and Falken FK451's. The Sumi's outperforms both.
Thanks, yeah I think I will get them.
Old Mar 16, 2004 | 08:43 AM
Ferbs02SMMax's Avatar
Dany,
These tires are amazingly good. They aren't the most expensive tire, but they do a damn good job in wet/snow, and are outstanding in dry/track conditions. They aren't noisy either. I love these tires, and coming from the oem's, well these tires are a definite kick in the a$$! If you go to the track often, you will love these tires, get ready for 2.1 and 2.2 60' times with these bad boys. They make them in non-proper load rating 225/45/17, or you can go with the 235 width, which I believe are proper load rating, and a wider footprint.
Get them, get them.
HTR+
See sig.
Fernando
Old Mar 16, 2004 | 08:53 AM
Dany's Avatar
Originally Posted by Ferbs02SMMax
Dany,
Get them, get them.
HTR+
See sig.
Fernando
What size are you running?
I was planning to get 235/45 size as it has proper load rating.
Old Mar 16, 2004 | 09:05 AM
F23A4's Avatar
I had the HTR4+ tires on my 626 and they were great for both performance and ride comfort. The exact balance RE92s aim for but fail at. Unfortunately, I need the correct load bearing which prevents me from going 225-45-17 (of which there's a MUCH larger selection).
Anyway, I've decided to splurge and pay the $800 price of admission for a set of Michelin Pilox HX MXM4s (stock size).
Old Mar 16, 2004 | 09:12 AM
225/45/17. Ride quality is unaffected, but technically, I shouldn't be driving with these things on.
Old Mar 16, 2004 | 09:17 AM
Dany's Avatar
I see, yeah I think I will go with 235/45 with correct load rating but with a slightly wider tire.
I know there has been alot of discussions about running 235/45 on our stock 17" rims and
it seems that many people run them with no problems.
Thanks again for your help.
Old Mar 16, 2004 | 09:19 AM
03BlkSETE's Avatar
Before you buy these tires, check out the linked thread, in particular the post by Dave B. Apparently their is some type of problem with these tires that causes them to wear out prematurely.
http://forums.maxima.org/showthread....light=sumitumo
Old Mar 16, 2004 | 11:11 AM
Galo's Avatar
Maxima Pilot
Before you do that, check out my post (in the wheel and tire forum) about the new Turanza LS-Vs available now in the OEM 225/50 size.....I had the MXM4s and they suck.....noisy and poor grip. I got them at Sears and after more than $200 spent in various attempts at balancing them, they replaced them with the Michelin Pilot's A/Ss that just came off the car as well.
Check the Turanzas before you do the MXM4's!!!!
Old Mar 16, 2004 | 11:17 AM
Eenis's Avatar
I wish this was posted when I bought mine. As much as I love them, I'm at 21k now, and i'm getting close to the end. if they lasted longer i'd buy a second set in a heartbeat.
Old Mar 17, 2004 | 02:32 PM
Have they shown even wear? Or has the middle worn prematurely like Dave's did? I guess I'm lucky since my tires wore out normally.
Old Mar 17, 2004 | 08:24 PM
Eenis's Avatar
From my observation and reviewing the treadrating info from when I got my tires rotated, they've worn evenly. At one rotation, the guys said I had a cupping problem, but i only heard it once and couldn't find it in the records. They've been pretty even....just fast.
Old Mar 17, 2004 | 08:29 PM
NYCe MaXiMa's Avatar
I have these tires.. they rock
they are on my stock 17s in 245/45/17 and are awesome in the rain, amazing in the dry.. and pretty damn good in snow..
best all season performance tire for the money, period.
i don't know anything about premature wear.. if they give me 2 years of use.. which is about 30-35k miles, i'm happy.. for the price, you can't go wrong..
Old Mar 17, 2004 | 09:43 PM
Eenis's Avatar
How's that fit w/ the 245's on the stock rims? No problems at all? Would you run that size again, or would you step down to 235/45
Old Mar 18, 2004 | 08:06 AM
a33se's Avatar
I've got them, I have at least 36k+ on them and have been great. the fronts probably have about 35% left, i think it'll last thru summer. But like another member here, I got lazy rotating them where my back tires are still like 70% good. My wife drives the car mostly whose not as aggressive a driver as i am so that may explain the longer life plus i used light weight rims. For the money, they are the best, outstanding grip, even wear, relatively quiet. the Michilens pilots are probably better but they're like double the price.
Old Mar 18, 2004 | 10:08 AM
JeffesonM's Avatar
living out of a maxima...
I'm on my second set and will probably get a third whenever these get bald. Very satisfied.
Old Mar 18, 2004 | 10:15 AM
Raf2kMax's Avatar
maybe the problem is with the 235 size? and not the 225?
Old Mar 18, 2004 | 11:46 AM
Eenis's Avatar
Jefferson, what size were you running, and how many miles did you get out of them?
Maybe the tire size is the problem. I was expecting reduced life from my 225/50's, but this is looking to be ridiculous.
Old Mar 18, 2004 | 01:39 PM
Eenis's Avatar
I retract my previous statement.......
I obviously haven't been paying attention, but I have gross uneven wear on the tires. Inside tread is just about at the wear bars, outside tread looks like it's almost 2x that amount (give or take). as much as i like the grip of the tires, guess who may be going back to 225/50 on some falkens?
MR2 T'd
Jul 9, 2021 05:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
