New Tires on 2003 GLE
Old Mar 18, 2004 | 01:29 PM
Derek03's Avatar
Hi!
Im looking for a little advise.
I hate the stock tires on my 03 GLE (215/55/17's) (Bridgestone Turanza EL42). They really blow, and frankly need to be replaced at 25k.
Here's the problem: I've only found two tires in this size, again, the Turanzas, and the Goodyears.
If I want to change the size to open up product range, what can I do?
Can I go to a 225/50/17, or should it be 235/50/17? Or can I even do a 215/50/17?
Any comments/suggestions are welcome! derek80@comcast.net
Thanks!
Old Mar 18, 2004 | 01:32 PM
2k3TitaniumSe's Avatar
Please post this on the wheel and tire section!
Old Mar 19, 2004 | 11:05 AM
.45's Avatar
.45
Without getting into all the details supporting my decison (it's in the .org Archive)... I replaced the EL42s on my 02' with A/S's, 225/50's on OEM rims. OEM spec'd load rating, diameter and other factors were considered to the nth degree. You have many options if you consider driving style, expectations,etc. then select a tire and run the numbers before you decide.
AaronL
Aug 8, 2020 10:31 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Need help
23
Oct 2, 2015 08:56 AM
Garrettz459
Sep 28, 2015 02:50 PM
