Bolt Pattern Question
Old Mar 30, 2004 | 01:29 AM
nizmo's Avatar
I kno the maxima bolt pattern is 5x114.3 but will 5x115 rims fit the 4th gen? Will I need hubcentric rings?
Thanx
Old Mar 30, 2004 | 08:00 AM
nupe500's Avatar
Jedi Knight
I don't believe that the wheels will fit...u should test fit before buying if possible...but I don't think so..also...you need to check the hub size to determine if you need the rings or not.
The Frye
Sep 2, 2021 11:03 AM
ef9
Sep 29, 2015 11:29 PM
mpbclutch33
Sep 21, 2015 01:54 PM
bumpypickle
Sep 19, 2015 01:07 AM
jcvgn
Sep 13, 2015 11:42 AM
