anyone running 255 up front
I am seriously considering 255 30 20s instead of 245 35 20s on all four corners. THe 255s are much closer to the stock diameter than the 245. Do you think I wil have any rubbing issues because they are 1 cm wider? Not likely. Ishouldn't have any rubbing issues on top because they are shorter than the 245s.
Just wondering if anyone is running 255s up front (doesn't really matter about the rim height just interested in width). Oh yeah the wheels are 20 x 8.5 and 38 mm offset.
Originally Posted by limsandy
Hint: someone has run 265/40/17 on their 5th gen Maxima.
~limsandy
~limsandy
Yeah i thought you had 265s but I thought they might be on the rears only. You are running 8.5 inch wide wheels right? 38 mm offset?
Any rub on full lock?
lowpost99
22
Sep 2, 2015 04:38 PM
