Rear wheel spacers: a good idea?
Old May 31, 2004 | 12:45 PM
Eric95se's Avatar
Anyone ever notice how tucked the rear wheels of the max look? I was wondering if it was a good idea to add spacer or if that would affect handling, offset, tire wear etc. Any help would be much appriceated.
Old May 31, 2004 | 02:33 PM
mrnock's Avatar
I think you'd get more accurate responses in the tires/wheels forum.
Old May 31, 2004 | 06:01 PM
d_warner's Avatar
Old Timer
Spacers are fine if you want your max to push in the corners like a freaking Dog!
Old May 31, 2004 | 06:36 PM
Mad-MAX_SE's Avatar
Still kickin'
D_Warner, would moving the wheels out like 15mm (widening the overall rear track by 30mm) really make that much of a difference? Me and a friend of mine were talking about getting some cause how recessed the rear wheels look. So in that same reguard would putting a wheel with a wider offset in the rear cause the same probs? i'm not doubting, but actually trying to learn, since it sounds like you have experience with this. i'm just like Eric95se, and i hate the way it looks. it wasn't so bad at stock ride height, but i've lowered it now, and it just looks odd. Any insight would be great from you or any others.
Old May 31, 2004 | 06:57 PM
d_warner's Avatar
Old Timer
The car is designed with a narrower rear track so that the inside rear tires track tighter in a turn. By moving the rear tires out, you essentially widen the turning radius by making the rear tires track further out. It's not a real big problem at lower speeds, cause the max turns pretty sharp as it is. But when you up the speeds, the wider track definately makes the car push. By increasing rear stability over that of the front in any manner you will run into that problem. The same thing would happen if you were to put 10 inch wide tires on the back and 8 inchers on the front.
Old May 31, 2004 | 07:46 PM
aspec0002's Avatar
ive got 5mm spacers in the front because the wheels i got just barely rubbed the caliper, so i got the spacers for 12 bucks, and my car handles great still, only i can tell the difference, but even still i do contemplate getting spacers for the back, it does look better with 5mm difference, the problem is i dont feel like getting longer studs in the back. the studs i got were 3mm longer and were stock from another car, got them at discount auto parts, ran me 2 bucks a piece, so for 40 bucks worth of studs and 24 bucks worth of spacers, you decide whether its worth it, i personally have better things to spend the money on.
Old May 31, 2004 | 08:45 PM
I30tMikeD's Avatar
I will be getting 15mm for the front and 20mm for the rear, purely cosmetic reasons.
Old Jun 1, 2004 | 01:15 AM
Ludacris's Avatar
Let us know how that goes...been wondering about it.
Old Jun 1, 2004 | 04:42 AM
nupe500's Avatar
Jedi Knight
Thats nothing...try spending $80 for 10 Nismo studs for the front..I say leave the wheels the way they are...it was bothering me at first...but I've let it go
Old Jun 1, 2004 | 07:18 AM
Bluesbrekr's Avatar
Doctorate in Detailing
5th Gen rears look really tucked, too. I'm hoping my new rims (18 x 8 with 38 offset) will push them out a bit. I was hoping to avoid using spacers.
Old Jun 1, 2004 | 07:23 AM
Mad-MAX_SE's Avatar
Still kickin'
Where are you getting the spacers from? Also, how should i measure for what size i need...just measure the distance from tire to wheel well??
Old Jun 1, 2004 | 11:26 AM
Eric95se's Avatar
NEXT QUESTION: So wheel spacers afect turning radius. Than I am not concerned about. What I do think about is that the addition of spacers shortens the length that the wheel nut can attach to the threaded bolt on the beam axle. Is it safe to add a small spacer without worrying that a nut will come loose?
Old Jun 1, 2004 | 11:59 AM
aspec0002's Avatar
thats where extended lug studs come in play, im actually pretty happy with the deal on mine, but with 15 & 20 mm spacers your going to have to go pretty long, expect to pay almost 100 bucks for just studs.
Old Jun 2, 2004 | 12:51 PM
I30tMikeD's Avatar
H&R makes hubcentric spacers for our cars. It will be about $200 for front and back. A little pricey but after consideration hubcentric is the only way to go and H&R is the only place that makes them.
I will either go with the before mentioned 20mm rear and 15mm front, or maybe 15mm rear and 5mm front. H&R does not make a 10mm spacer.
I am on stock 15's right now, but the 17's I used to have were 17mm further out than stock, which gave me a flush look in the front and just a tad tucked in the rear. So I know that 20mm rear and 15mm front will work just fine.
You can also measure using a 2' long 2x4 or something similar. Rest the 2x4 vertically against the wheels and mark with a pencil how far inset the top of the fender is.
Old Jun 3, 2004 | 03:25 AM
Norm Peterson's Avatar
You need to have at least one stud diameter of thread engagement in the nut. Anything less varies from risky to downright unsafe, depending on how much less it is. Some racing organizations (I think NHRA is one) require open-ended nuts so that this can be easily verified. On edit: if I was going to add spacers, I'd invest in a better grade of studs at the same time even if my existing studs were long enough per the above.
Maybe I'm just a wee bit dense this morning, but I can't see where spacing the rear wheels out a little wider on a FWD car could possibly affect the turn radius unless you're doing handbrake or left-foot-braking turns.
Norm
Old Jun 3, 2004 | 05:12 PM
Mad-MAX_SE's Avatar
Still kickin'
Are the they the type that you bolt on the stock studs, and use studs on the spacer?
Old Jun 4, 2004 | 05:30 AM
I30tMikeD's Avatar
Both. I **think** the 5mm and 15mm spacers just use longer studs and the 20mm and 25mm use the spacers that have the studs attached. I know for sure they use both kinds, just can't remember which sizes use which.
Old Jun 4, 2004 | 08:48 AM
Mad-MAX_SE's Avatar
Still kickin'
if the 15 does too, then i may have to get a set of those too...pending on what i'm going to do about a set of wheels i found.
Old Jun 4, 2004 | 01:19 PM
carabuser's Avatar
don't get your hopes up...
Old Jun 4, 2004 | 05:28 PM
C3nthusiast's Avatar
I have 10mm spacer on my rears.
Old Jun 16, 2004 | 12:47 PM
kingrukus's Avatar
no more maxima...
I have 3mm wheel spacers in the rear to clear the rear hubs. I did not want to go larger than that with stock studs. I am going to end up going with 5mm h&r spacers so I can put my rear hub sheilds back on.
Old Jun 17, 2004 | 04:04 PM
JoeJoe's Avatar
I got the 15mm in front and 20mm in back. Got them from http://www.optauto.com/webstore/prod...t=417&last=417
Looks alot better. Can't really tell a difference handling wise. There were a little expensive but to me were worth it. You can see some close up pics on page 3 of my website.
Huttig2009
Sep 25, 2015 03:31 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
BobMax
Aug 15, 2015 12:35 PM
