When only replacing a pair of tires, where to install them? (Tire Safety Sticky?)
Old Jun 19, 2004 | 05:23 AM
RichSpidizzy's Avatar
Good article I saw on TireRack. Thought it would be a good thing to read for those who didn't already know:
Where to Install New Pairs of Tires. Intuition Isn't Always Right
Most vehicles are equipped with the same size tire at every wheel position. Ideally all of these tires should also be of the same type and design, have the same tread depth and be inflated to the pressures specified by the vehicle placard or owner's manual. This combination best retains the handling balance engineered into the vehicle by its manufacturer.
However due to the front tires' responsibility for transmitting acceleration, steering and most of the braking forces on front-wheel-drive vehicles, it's normal for front tires to wear faster than rear tires. If the tires aren't rotated on a regular basis, it's also common for pairs of tires to wear out rather than sets. And if the tires aren't rotated at all, it's likely that the rear tires will still have about 1/2 of their original tread depth when the front tires are completely worn out.
Intuition suggests that since the front tires wore out first and because there is still about half-tread remaining on the rear tires, the new tires should be installed on the front axle. This will provide more traction, and by the time the front tires have worn out for the second time, the rear tires will be worn out too. However in this case, intuition isn't right...and following it can be downright dangerous.
When tires are replaced in pairs in situations like these, the new tires should always be installed on the rear axle and the worn tires moved to the front. The reason is because new tires on the rear axle help the driver more easily maintain control on wet roads because new, deeper treaded tires are more capable of resisting hydroplaning.
Hydroplaning occurs when the tire cannot process enough water through its tread design to maintain effective contact with the road. In moderate to heavy rain, water can pool up in road ruts, depressions and pockets adjacent to pavement expansion joints. At higher speeds, the standing water often found in these pools challenge a tire's ability to resist hydroplaning.
Exactly when hydroplaning occurs is the result of a combination of elements including water depth, vehicle weight and speed, as well as tire size, air pressure, tread design and tread depth. A lightweight vehicle with wide, worn, underinflated tires will hydroplane at lower speeds in a heavy downpour than a heavyweight vehicle equipped with new, narrow, properly inflated tires in drizzling rain.
If the rear tires have more tread depth than the front tires, the front tires will begin to hydroplane and lose traction on wet roads before the rears. This will cause the vehicle to begin to understeer (the vehicle wants to continue driving straight ahead). Understeer is relatively easy to control because releasing the gas pedal will slow the vehicle and help the driver maintain control.
However, if the front tires have more tread depth than the rear tires, the rear tires will begin to hydroplane and lose traction on wet roads before the fronts. This will cause the vehicle to begin to oversteer in which the vehicle wants to spin. Oversteer is far more difficult to control, and in addition to the initial distress felt when the rear of the car starts sliding, quickly releasing the gas pedal in an attempt to slow down may actually make it more difficult for the driver to regain control, possibly causing a complete spinout.
Members of The Tire Rack team had the chance to experience this phenomenon at Michelin's Laurens Proving Grounds. Participants were allowed to drive around a large radius, wet curve in vehicles fitted with tires of different tread depths — one vehicle with new tires on the rear and half-worn tires on the front, and the other with the new tires in the front and half-worn tires on the rear.
It didn't take long for this hands-on experience to confirm that the "proving grounds" name for the facility was correct. The ability to sense and control predictable understeer with the new tires on the rear, and the helplessness in trying to control the surprising oversteer with the new tires on the front was emphatically proven.
And even though our drivers had the advantage of knowing we were going to be challenged to maintain car control, spinouts became common during our laps in the car with the new tires on the front. Michelin advises us that almost everyone spins out at least once!
Experiencing this phenomenon in the safe, controlled conditions of Michelin's Laurens Proving Grounds rather than in traffic on an Interstate ramp in a rainstorm is definitely preferred!
In case there is any doubt, when tires are replaced in pairs, the new tires should always be installed on the rear axle and the worn tires moved to the front.
Old Jun 19, 2004 | 07:27 AM
Bobo's Avatar
Thanks for the post. I was going to buy 2 new tires for the front in 10,000 miles or less. I can't rotate my tires because I had a flat about 7,500 miles ago and my spare is on the right rear and I can't bring them to the front because of the tread differential - I am told it may cause the car to pull so just leave them where they are given the car has 53,000 miles on it. It looks like I will end up buying 4 tires, although the car is not driven in the rain much.
Old Jun 19, 2004 | 12:23 PM
limsandy's Avatar
I'm too lazy to read the whole thing. Just responding to the question in your title, the new tires should be installed in the rears..... for Maximas, that is.
~limsandy
Old Jun 20, 2004 | 06:00 AM
z32drifter's Avatar
I have read this before and still feel that it is good for people who can't drive......I put the better tires on the front...... always have and always will.... the thing that they left out in the real world is your front brakes (tires) do 70% plus of the braking and also have to turn and accl the car.... the instance of hydroplaning is manufactured by driving to fast for conditions..... sure if you are driving 10/10ths understeer is eaiser to control.... however if you drive 10/10ths on the street you should maintain good sticky tires at all times...... for the adverage driver who drives 5/10ths I think the added braking power afforded by better tires in the front out weight the risk of hydroplaning the rearend out of control......... just my 2cents
Roymg
Sep 3, 2018 05:10 AM
District
Aug 15, 2015 08:23 PM
mls277
Aug 11, 2015 07:18 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
