Uneven tire wear in rear tires causing "wha wha wha" sound?
Old Jul 8, 2004 | 06:11 AM
Maxima 504's Avatar
i took my max with 118k to a friend at a nissan dealership looking to get my rear wheel bearings replaced thinking that they were the cause for the sound I was hearing. I get a bad tire hum sounding like "wha wha wha". The tread on my kelly tires om stock rims is wearing similar to mud tires. Every other tread is a different height, but they have a good amount of tread on them.. The tread is heigher on one and lower on the next in that pattern. any help is appreciated.. thanks
Old Jul 22, 2004 | 07:47 AM
zazon's Avatar
im having the same kinda problem except on my front end, if you move the tires to the front do you still hear it in the same spot?
Old Jul 26, 2004 | 04:11 AM
I30tMikeD's Avatar
Your tires are chopped. Nothing you can really do except replace them. With your new set of tires make sure you properly maintain them with rotations and alignments. Also check to see what type of condition your shocks are in, they can be the cause of chopped tires many of times.
Old Jul 26, 2004 | 11:54 PM
E55AMG2's Avatar
Wat
sounds like you have a tie rod or balance problem. Basically, some component in your suspension is worn out, or you wheel is severely out of balance, or both. Have them inspect the suspension and the wheel balance. Thats usually the cause of your problem.
Old Jul 27, 2004 | 04:11 AM
zazon's Avatar
yeah i would really like to figure out how this happened. i cant get a straight answer out of tire america, they just want to sell me new tires.
Old Jul 27, 2004 | 09:24 AM
E55AMG2's Avatar
Wat
Ill tell you how, worn suspension components. Also, of course they wanna sell you new tires. They cant fix whats wrong, so they wanna sell you new tires to mask it.
Roymg
Sep 3, 2018 05:10 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
