Tire pressure in cold weather...
Old Dec 12, 2004 | 03:55 PM
Fork's Avatar
Maximaler Experte
Does anyone know of a psi chart that converts for colder weather? I.e. 32psi at 75F, what would that read at 0F? Do I still maintain 32psi at 0F?
Old Dec 12, 2004 | 06:04 PM
CanadianMoFo's Avatar
You maintain the tire pressure no matter what the temperature is. When the temperature drops be aware that your tire pressure will drop as well, and you will need to add air to the tires. The opposite is also true, as the temperature rises the tires will increase in pressure and some air will have to be let out.
For every 10F change in temperature the pressure will change by 1PSI (approximately). I'm too lazy to change that into Celcuis for ya.
CM.
Mar 12, 2020 12:06 AM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
thenewguyy
Sep 12, 2015 11:12 AM
jfl330
Sep 4, 2015 01:44 PM
