is a little rubbing bad?
Old Jan 27, 2005 | 10:25 PM
steven88's Avatar
Need A Light?
okay...I would like to know if rubbing is bad? bad for the car, bad for the tire...whatever....and i'm not talkin bout severe rubbing...like just a small pitched rubbing noise when u lock out the steering wheel (u-turns)....
the reason i ask is becuz on my 2k2 with D2 coilovers...I am rubbing only when i lock out my steering wheel to the left...its not a big rub either....just minor...was wondering if this will hurt anything?
Old Jan 27, 2005 | 10:42 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
nah, you should be ok.... I've had rubbing with no probs... eventually the tire will wear and it goes away (maybe)...
Old Jan 27, 2005 | 11:02 PM
steven88's Avatar
Need A Light?
Yeah hopefully....cuz I just got new tires today....so i'm assuming that its rubbing becuz the tire is brand spanking new....and the tread is real thick and beefy so it sticks out a tad bit more than my BALDED old tires....
anyway, anybody else wanna comment on rubbing? good?...bad?
Old Jan 28, 2005 | 12:15 AM
Bonka's Avatar
Schnell kaputt
I rub the inside wheel well full lock left and right. Left's a little worse but I couldn't notice any premature wear on the tires.
It only rubs the corner of the tire (where the sidewall and contact patch meet) it's no problem.
Old Jan 28, 2005 | 08:55 AM
steven88's Avatar
Need A Light?
rubbing shouldn't prematurely wear the tires right? I mean my rubbing is only very minor (not loud) and its only for a few seconds when making a u-turn.....and its not like I make a u-turn every single corner.....so it shouldn't prematurely wear the tires right?
oh yeah i don't rub when i go over speed bumps....none at all actually....only when i lock out my steering wheel to the left...
Old Jan 28, 2005 | 08:57 AM
Bman's Avatar
I would get under the car and check exactly what it is rubbing and how badly. Just going by sound isn't a very good way to judge this. It's better to know and find out now, rather than to find out it rubbed right through a fender liner or chewed up the side of the tire later on.
A "little" rubbing should be okay if it's not damaging anything, but make sure it really is just a little. Some tires in the same size differ a bit in measurement from one model/brand to the next, which might be another factor.
Old Jan 28, 2005 | 09:25 AM
steven88's Avatar
Need A Light?
I shall lock out my steering wheel and turn off the car....then examine the tire.....later down the road that is...right now it's too early cuz i just barely got the tires...thanks for the tip!
Old Jan 28, 2005 | 09:55 AM
Bonka's Avatar
Schnell kaputt
If the tires are rubbing against the inside fender liner, you could always grind down the area. The tire marks will indicate the areas that need grinding.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
