G35 wheels w/300ZX brakes
Old Mar 28, 2005 | 06:15 PM
jblinga's Avatar
Will G35 wheels clear 300ZX brake calipers?
Either of these models. & do they bolt up to 4th gen?
Old Mar 28, 2005 | 06:33 PM
irish44j's Avatar
retired moderator
can't tell you for sure, but both of them EASILY clear the 6th gen rotors/calipers that I have on my 2000 max....
I use the 18's for daily driving (tons of brake clearance) and the 17's for auto-x, with less clearance. Since they will clear the brembos on the G35C, they should clear the 300z brakes no problem.
Old Mar 28, 2005 | 06:35 PM
irish44j's Avatar
retired moderator
note that the one on top (the 17) there are 2 types:
sedan 17 which is 17x7 with a 40mm offset and the
coupe 17 which is 17x7.5(f)17x8(r) with 30(f)/35(r) mm offset.
for maximum clearance, make sure you get the coupe 17's, NOT the sedan 17s...they look almost identical.
Old Mar 29, 2005 | 10:17 PM
Talyan03's Avatar
they should beacouse some modela have brembo's
Old Mar 30, 2005 | 12:53 AM
SEmy2K2go's Avatar
Go BUCKS!!!
- what?
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
