Offset ???'s. Advice Please.
Old May 2, 2005 | 07:27 PM
BRAN808's Avatar
What's the possibility that a 19"x7.5" wheel with a +45 offset will fit on a 5th gen Max? Do any of you wheel guru's forsee any rubbing issues? It seems like I always get myself into this. I ran into the same problem when I picked up my set of G35C's. I had some rubbing issues because of the rear wheel drive offset (+30). I'm currently on Tein S-Tech's, but will probably be getting coilovers shortly. Now I may be going the other way. I just ran into a guy selling a set of 19" RH C2's ( 3piece ones) for fairly cheap. If they'll fit with no problems, then I may consider picking them up.
Old May 2, 2005 | 10:37 PM
Ammi's Avatar
350 Detroit Muscle
they should fit just fine although I would push them out a bit.
Old May 3, 2005 | 09:50 AM
BRAN808's Avatar
When you say "push them out," are you refering to using wheel spacers? Are there any down falls to using spacers? I just don't want to damage anything. What exactly is the optimum offset for a 5th gen Max?
Old May 3, 2005 | 10:47 AM
Ammi's Avatar
350 Detroit Muscle
well with 19x7.5, I would run 30-35 offset.
You can use 5mm spacers but anything bigger, you'll need longer studs.
Old May 8, 2005 | 12:12 PM
BRAN808's Avatar
If you go with a 5mm spacer, is there any chance of it damaging anything? I can't really see how, but just curious. Thanks in advance.
Old May 8, 2005 | 01:29 PM
Ammi's Avatar
350 Detroit Muscle
Nothing that I know of. I've been using 5mm spacer for a year or two and no problem yet.
Old May 9, 2005 | 02:48 AM
BRAN808's Avatar
What is the offset on the wheels that you're using with the 5mm spacers? So, let's say they're originally a +45, does that now make it a +40 if you use the spacers?
Old May 9, 2005 | 04:37 AM
Ammi's Avatar
350 Detroit Muscle
I've used w/ my 18x8.5 rims with 42mm offset and 18x7.5 with 40mm offset.
Yes using 5mm spacers on a 45mm offset would give you a 40mm offset
Old May 9, 2005 | 12:43 PM
ThurzNite's Avatar
What width tire are you running? I don't think all 235/35-19 tires will fit 7.5" wide. 245/35-19 is cautioned.
Jae
Old May 9, 2005 | 01:56 PM
BRAN808's Avatar
Thanks Ammi!
Old May 9, 2005 | 02:45 PM
$tillenmax2k
Honestly, the best option would be to find wheels at least 8" wide, and then use an offset between 35-42mm.
There's no point in fitting the car around some wheels, just get wheels that fit in the first place. Spacers should be used as a last resort, in case you order wheels before consulting someone knowledgeable in that area, or when you already have a set of wheels and suspension or brake components are changed and no longer have clearance.
Old May 12, 2005 | 06:21 PM
amomaxima's Avatar
can someone expalin the offset to me and tell me what offset i can go with the make 8.5 width fit my tire well without issue. i have the sway bar which extends my brake lines out and has reduced the size tire/rim i can use HELP
Old May 12, 2005 | 06:44 PM
Ammi's Avatar
350 Detroit Muscle
What size? 18x8.5? You can go 245/40/18s and offset between 35-40
Old May 13, 2005 | 03:14 PM
amomaxima's Avatar
ok so if the offset is lower or higher what does that refer to???
Old May 13, 2005 | 03:18 PM
Ammi's Avatar
350 Detroit Muscle
lower the offset, further wheels stick out
Old May 17, 2005 | 10:03 AM
Hokie350Z's Avatar
Thought I would ride the wave of offset questions:
Am I asking for trouble with a 19x8.5 with 20mm offset and 245/35-19's? I can get a great deal on Alessio F1's intended for G35/350Z but want to put them on a '02 Max. My car's not lowered yet but I'm leaning toward Maxspeed springs. What do you guys think?
Old May 17, 2005 | 06:44 PM
Ammi's Avatar
350 Detroit Muscle
You will definitely rub with 20mm offset. They will stick out too far
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
