45mm would it be too tucked in?
Old Jul 29, 2005 | 05:12 PM
thephatOne's Avatar
Hey guys I can get some 19x8 rims but they are 45mm, I drive a 2000 infiniti i30, would it look wierd? (wheels too tucked in looking) Can I use spacers of somesort to widen the cars stance?
Old Jul 29, 2005 | 09:23 PM
icelandmaxima's Avatar
Maxima Fanatic
I've got 42mm and it looks fine but I opted for a higher offset so that i wouldnt rub when I lowered. If the look doesnt satisfy you can always get spacers.
Old Jul 29, 2005 | 09:29 PM
Maxima Fanatic
On second thought a 45mm may be a little to tucked in. If you can get the wheels in a lower offset do so otherwise you can use spacers the only reason I went so high was to be absolutley sure I wouldnt have any rubbing issues.
Old Jul 30, 2005 | 12:41 AM
BRAN808's Avatar
I had a set of GramLights with a +40 offset and 8" width,and that to me, looked too tucked in. I'm running my other set of G35's right now, and they're an 8" width with a +30, and the look is perfect. I'm on 235/40/18's in the back and pretty slammed on Ksports, and no rubbing what so ever.
Old Jul 31, 2005 | 07:05 AM
Nealoc187's Avatar
SLOW
45mm on an 8" wheel will be way in there yes. Unless they are some incredible crackhead deal I'd keep looking.
Old Jul 31, 2005 | 10:52 AM
chillin014's Avatar
what about 17x7 42mm?
Old Aug 1, 2005 | 06:04 AM
ICULookN's Avatar
What about 19x8.5 with 34+ offset?
Old Aug 1, 2005 | 04:22 PM
Ammi's Avatar
350 Detroit Muscle
not any better
Old Aug 1, 2005 | 04:23 PM
Ammi's Avatar
350 Detroit Muscle
that's better
Old Aug 1, 2005 | 08:02 PM
ICULookN's Avatar
Originally Posted by Ammi
that's better
Will 15mm spacers be ok? Thanks.
Old Aug 2, 2005 | 08:11 AM
thephatOne's Avatar
I think instead of the whole aftermarket look, Ill stick OEM, if I can get my hands on some G35, M45 wheels Ill probably get those.
Old Aug 2, 2005 | 08:14 AM
Ammi's Avatar
350 Detroit Muscle
For the rears. Just get rims with correct offset because w/ 15mm spacers, you'll need longer studs and possibly, open end lugs as well
Old Aug 9, 2005 | 08:03 PM
HomerMAC's Avatar
Donating i30 Owner
or theres a guy who makes adapters.. that bolt to your stock lugs then teh wheels atach to the adapter.... He custom makes them .. so give him teh size you want and he can make them.. email me.. if interested .. im gonna have a pair made..
Old Aug 10, 2005 | 07:11 PM
irish44j's Avatar
retired moderator
for comparison's sake, here are my rims (8" wide also) with a 30mm offset....now imagine them "in" 15mm I personally like them flush with the sides, the way European cars do it...
[IMG]
Old Aug 10, 2005 | 09:14 PM
ICULookN's Avatar
No spacers? The front seems to be even with the sides a little more than the rear but still looks way better than stock.
Old Aug 11, 2005 | 09:03 AM
irish44j's Avatar
retired moderator
no spacers....but it's a 30mm offset on an 8" rim compared to 42mm offset on a 7" rim stock. That means the rims on mine come "out" 12mm+1/2"(roughly13mm) = 25mm
so that's what stock rims would look like with a 25mm spacer.
Garrettz459
Sep 28, 2015 02:50 PM
KMD
Dec 3, 2002 09:39 PM
ptrkng
Jun 21, 2002 03:23 PM
theblue
22
Jan 22, 2002 08:28 PM
philpoe
Jan 3, 2002 09:05 AM
