Wheels/tires Sticky? G35 wheels on maximas
Old Apr 11, 2007 | 02:24 PM
  #441
00MaxSE's Avatar
Pointy Elbows
35... no rubbing, closest to stock DIA. But then again if your roads are horrible, you should've be considering 19s...
Old Apr 11, 2007 | 02:44 PM
  #442
irish44j's Avatar
retired moderator
Originally Posted by joebangaa
245/40/19
eibach/h&r/progress for the drop paired with illuminas
WRONG!
Assuming you're going with a 245-width tire on a 19" rim, to keep stock diameter you need 245/35/19
40-series will be almost a full inch bigger in diameter, FTL.
Old Apr 11, 2007 | 05:10 PM
  #443
00MaxSE's Avatar
Pointy Elbows
Originally Posted by irish44j
WRONG!
Old Apr 12, 2007 | 08:05 AM
  #444
Greeneyes's Avatar
Originally Posted by Deckdout2
Thanks Greeneyes. That's the answer I was looking for. Good thing I have 4 5mm spacer plates that I couldn't sell. I'm going to use those to bring the wheel out a little so I won't have to do any pounding.
Ok, off to search the forum regarding 5mm spacers w/o using extended lugs. I remember reading about this a bit, but now that I'm going to do it, just need to refresh my memory.
Happy ridin' dirty.
If your going to use the stock G35c tire size on the rear tires and youre dropped you might not be able to put those spacers on the rear. I would just pound that metal cap on the wheel hub in if I were you, it pushes the caps off when you try putting the wheel on... Just pop the caps in and try putting in the rim you'll see what im talking about when you try setting the wheel in.
For the front I would suggest putting the wheel on the car first then popping the caps on... You will have to be careful putting on the front ones as you will have to level them off good... they dont pop in all the way but they will still stay on. Ive had mine on for over a year now and havent lost any.
Old Apr 14, 2007 | 12:07 PM
  #445
Maxima03GLE's Avatar
So if I go with the 18" G35's on H&R's what tire size is best? Does anybody have this set and can tell me how it rides? How long will the GLE stock struts hold out? i got 62k on it right now. Thanks for the help guys.
Arick
Old Apr 14, 2007 | 07:11 PM
  #446
joebangaa's Avatar
WRONG!
Oh **** my mistake. That's funny because I'm running 245/35/19 all around so I really shouldve known better.
Old Apr 14, 2007 | 08:45 PM
  #447
irish44j's Avatar
retired moderator
Arick
235/40/18 is preferred.
The GLE stock struts at 62k won't hold out long on lowered springs. Just get new struts when you do springs, so you don't have to take it all apart twice.
Old Apr 14, 2007 | 09:13 PM
  #448
Thanks guys for all your replys. Honestly, i will never race this car so are illuminas really worth the extra cash? I just want the softest ride i can get.. and from what i read H&R are the best bet in that dept. I have seen some ppl (albeit a few) that only install the front springs. How bad is this for my ride? and last question. irish what center caps are you running on your ride.
arick
ps
irish your ride looks bad a$$
pss
last last question
Can anybody compare the their ride after lowering and putting rims(18's) on it compared to stock.1-10 scale.
Old Apr 15, 2007 | 08:22 PM
  #449
irish44j's Avatar
retired moderator
arick
ps
pss
last last question
1. Yes, they are worth it, because they have adjustable ride firmness. If you want soft, dial them to "1" OR "2" and they will be downright boat-like. If you want more like stock, a "3" is good. I run mine at "5" and they are not too harsh even on crappy local roads.
2. H&Rs are good for ride quality, possibly the best of what's available aftermarket. They need to be paired with Illuminas though....any aftermarket springs will blow your stock struts relatively quick.
3. thanks...it looks ok sometimes
4. Ride quality is affected by alot of things....tire size, tire brand, springs, struts, other suspension (bushings, sway bars), chassis changes (bushings, SFCs).
example: My 18s with Toyo Proxes 4 tires ride better than my stock 17s with falken 512s on them. Different tires have different stiffness of sidewalls, which can greatly affect ride quality and handling.
On a scale of 1-10, with my 18s, Eibachs, and a ton of other stuff done...If stock ride is a 10 (best) I'm probably at a "7" or so....but with H&Rs and the right tires, you could still have a "9"
Old Apr 15, 2007 | 09:35 PM
  #450
Wheels are being shipped out and should be there when i get back to the states. Thanks for your help. Only two things.. Center caps(read alot that says the stock wont fit), and front springs only? whats your take on that? This forum has been a big help.. thanks guys.
arick
Edit: what kind of front lip do you have on your car?
Have you had H&R's? how would you compare them to your eibachs?
Old Apr 16, 2007 | 03:08 PM
  #451
irish44j's Avatar
retired moderator
arick
The center caps will fit, but you have to bang in the side edges of the rear dust caps.
The front lip (if you're talking to me) is from a Mach 1 Ford Mustang, customized. there's a thread about it someplace in the 5th gen forum.
I have not used the H&Rs personally, but from what I know they are softer than the Eibachs.
Old Apr 16, 2007 | 07:42 PM
  #452
Deckdout2's Avatar
Play with my balls
Let's see how they'll fit and match up to the tint of the wheel once they're delivered.
I'm also going to give my 5mm spacers a try as well (only thing that wouldn't sell off the car).
How do you think the G 18's would look with silver tuner lugs instead of the acorn ones? If they're around the same price as the acorn, I might give that a try. Anyone have any good deals on them currently?
Old Apr 16, 2007 | 07:56 PM
  #453
Deckdout2's Avatar
Play with my balls
Thanks, I'm going to take this in consideration when I mount them Wednesday. I'm actually going with Khumo ASX's 235/40/18. Were you referring to the rubbing, when using the stock tire size off the G? I (hopefully) will be ok, and will investigate with my fingers crossed.
Old Apr 16, 2007 | 08:10 PM
  #454
irish44j's Avatar
retired moderator
Paramy, PLEASE do not use "tuner" lugs if they are spline-drive. I personally stripped out two sets of spline-drive lugnuts/lug tools (quality brands, not cheapos) and have seen two other people with the same problem.
Buy a standard 6-point lugnut. I use Gorilla lugnuts with a longer shank than the acorns....
Old Apr 16, 2007 | 11:14 PM
  #455
MrDicks95SE's Avatar
Offset Is Everything.
i didnt read the enitre thread but do hub bore sizes become a factor? ours is 67.1 and theirs is a 73? im assuming since their wheels fit we should be okay? im talking about aftermarket setups for the 350z/g35 on a maxima.
Old Apr 17, 2007 | 05:53 AM
  #456
Deckdout2's Avatar
Play with my balls
Thanks Josh, I've never used Spline-Drive lugs before. These are the one's you're referring to right?
I used the tuner lugs below for my 19's, and didn't give me a problem, except for a little rust in the center. What are your thoughts on these? They were what I was going to try again. I've never like the Spline-Drive anyway.
Old Apr 17, 2007 | 03:02 PM
  #457
irish44j's Avatar
retired moderator
yeah those should be ok....I usually associate spline-drive with "tuner" lugs for some reason.
I just use a standard long lugnut, which can be taken off with a standard lug wrench and no special tools
Old Apr 24, 2007 | 06:33 AM
  #458
BLKMAX005SPD's Avatar
Originally Posted by maxwannabenow
Got me a set of the G35 coupe 18's a couple of weeks ago...
you still have all the stickers i put on the car? Its looking good! keep up the good work
Old Apr 24, 2007 | 06:43 AM
  #459
maxwannabenow's Avatar
All except that Bush/Cheney sticker.. that went immediately!!
Old May 5, 2007 | 10:36 AM
  #460
djsan67's Avatar
Hey guys I Currently have the 17 inch G35 rims that come with the 2004 sedan (6spoke) just curious if they will go ontop a 95-99 Nissan Altima? is the bolt pattern, etc the same as the g35 and maxima? Please let me know as my spouse wants to switch cars.
Old May 5, 2007 | 11:53 AM
  #461
irish44j's Avatar
retired moderator
they should fit fine.
Old May 5, 2007 | 12:02 PM
  #462
djsan67's Avatar
thanks for the quick reply
Old May 6, 2007 | 02:29 PM
  #463
Teufelhunden's Avatar
how much does the 19" g35 wheels weigh?
Old May 12, 2007 | 05:27 PM
  #464
Gismo-T's Avatar
B!tch We Got a Problem
Is anybody rolling on 245/40/18's on G wheels? I'm getting my G wheels on Monday and would like to get 245's, but I'm lowered on Progress springs so I don't know if I should just stay 235's.
Can someone help on this.
Thanx,
Geo
Old May 12, 2007 | 06:05 PM
  #465
Dan5.5's Avatar
I thought the older altimas ,were 4 lugs. I am not a 100 perecent sure. If u meant maxima, then yes.
Old May 12, 2007 | 06:34 PM
  #466
irish44j's Avatar
retired moderator
Thanx,
Geo
the 245s should fit, but it will depend on the tire. If you want to be safe, go with 235/40/18 with such a low drop.
Old May 13, 2007 | 10:44 AM
  #467
Gismo-T's Avatar
Hey Josh,
What do you think about the Kumho Ecsta Sport KU31 tires?
Would you recommened those at all or just get the Toyo Proxes 4's?
Old May 14, 2007 | 10:08 AM
  #468
As far as the impact to your speedo goes you can check here...
http://www.miata.net/garage/tirecalc.html
Looks like it will make about a 1.5% difference (speedo will be lower than actual speed)
Old May 14, 2007 | 07:37 PM
  #469
irish44j's Avatar
retired moderator
Hey Josh,
Honestly, I know nothing about the Ecstas. The Proxes4 are a good tire - highly recommended.
Old May 14, 2007 | 07:42 PM
  #470
irish44j's Avatar
retired moderator
Originally Posted by mdillian3690
Hey guys I am unable to start a new thread. I currently have 215/55/16 on my 1997 Maxima. Would I be able to put 205/60/16 on the car? Will there be any issues? Speedo? There is a good sale on ContiProContacts for the 205/60/16s. Thanks!
ok:
this is not the way to go about asking a question. You don't hijack other threads (especially stickies) with off-topic questions. First, you do a little bit of searching. Second, you post in the N00b thread in the 4th gen forum, which is there so stupid n00bs can ask stupid questions (like this).
Please delete your two posts, and post your question in the right place, and everyone will be happy.
you wouldn't want to get the , now would you?
kthanxbye
Old May 22, 2007 | 06:01 PM
  #471
STILLENGLE's Avatar
Originally Posted by Jeff92se
Irish. Is that the oem finish? Looks lighter than mine
what version of the G35 Rims do you have on your car.
Old May 29, 2007 | 03:37 PM
  #472
Mr. Cummings's Avatar
Theres someone in NJ selling them on Ebay for $350, but you have to pick them up and the tires arent that good. Im in atlanta, so im out of luck.
Old May 30, 2007 | 02:18 PM
  #473
replicant's Avatar
so about 15k miles ago i replaced my stock protenzas with michelin pilot sport a/s, at the time i didn't really care to do wheel upgrades, but after seeing the g35 wheels on the maxima, i completely decided that was the way to go. so now i'm stuck, i like the 18" g35 wheels, but would love to just get wheels to go with my current 17" pilots. if you were in my situation would you bite the bullet and spend even more money to get the 18" wheels with new 18" tires, or would you simply just try and find the 17" g35 wheels to go with your existing 17" michelin pilots? yeah this is such a noob question i'm sure, just curious of your thoughts though. thanks all.
Old May 30, 2007 | 03:48 PM
  #474
tripleGmax's Avatar
buy sell buy sell buy sell
Old May 30, 2007 | 06:06 PM
  #475
irish44j's Avatar
retired moderator
do what i did....get both!
Old May 31, 2007 | 07:46 AM
  #476
joebangaa's Avatar
Ride on those 17"s for a while until you find a good deal on a set of 18"s. Once you do, just keep the 17"s for long trips or if some @sswipe decides to slash your tires (God forbid).
Old Jun 11, 2007 | 06:14 PM
  #477
Nyarlathotep's Avatar
I was lucky enough to get a set of the 6MT wheels sunday. I have 20mm spacers on the rear with 17" enkie DM5s right now. Will the 18" G35 wheels fit with spacers on? Will I have to get rid of the spacers or get the fenders rolled? Thanks
Old Jun 11, 2007 | 06:48 PM
  #478
00MaxSE's Avatar
Pointy Elbows
I really doubt that 20mm spacers will work with those wheels. Aren't they like a 33mm offset or something?
Old Jun 11, 2007 | 07:12 PM
  #479
irish44j's Avatar
retired moderator
they will not fit with the spacers. The 18's are 30mm offset.
i.e. that would make them a 10mm offset in the rear with spacers.
The biggest spacer you "might" be able to get away with are 10mm, and you'd have to roll the fenders probably.
Old Jun 11, 2007 | 07:18 PM
  #480
00MaxSE's Avatar
Pointy Elbows
^Yeah what Mister mod said.
