Wheels/tires Sticky? G35 wheels on maximas
Old Mar 6, 2007 | 01:04 PM
  #401
Deckdout2's Avatar
Play with my balls
I'm wondering if the center caps from the 5.5 gen SE's fits the 18" 7 spokes.......Anyone?.........Anyone?..........Buel ler?
Old Mar 6, 2007 | 04:27 PM
  #402
babyboyws6's Avatar
i would like to know the same thing actually, good question
Old Mar 17, 2007 | 09:25 PM
  #403
NissLover's Avatar
Heres my I30 with G35 sport alloys with G35 stock 215/55/17. What do yall think?
Old Mar 17, 2007 | 09:37 PM
  #404
00MaxSE's Avatar
Pointy Elbows
^ Looks very good, but what is the difference between the 1st and 2nd pic besides the car on the street being gone.
Old Mar 17, 2007 | 10:28 PM
  #405
NissLover's Avatar
LOL, ummmmm The sun is slightly shining on the car in the second picture? I don't know I just posted all the pictures I took after I wiped it down and cleaned the wheels.
Old Mar 20, 2007 | 03:56 AM
  #406
S13ORLANDO's Avatar
18" G35 wheels with curb rash
Originally Posted by cutter
Go for the 18's I think they look a lot better on our cars. I see me and you have the same car and I would say go with the 18s. Keep your brand new tires and use the 17s for the winter or something, but definitely go with the 18s.
Going to buy a set of 18" G35 Coupe wheels today.
They are the OEM wheels.How hard is it to remedy CURB RASH on these wheels?
I have seen Wheel GUYZ work their magic with various Stones.
Are these wheels easy to remedy light curb rash?
thanks,
Bob
Old Mar 20, 2007 | 08:01 AM
  #407
99MAXSE-L's Avatar
Ok so i found a pair of 18" g35 wheels...
the fronts: 225/45/18
the rears: 245/45/18
So will these tire sizes be ok on my 99 max? I dont think ill have any rubbing issues, my car is as high as it can get.
Would i need to buy 235/40/18 for both the front and rears?
I seriously dont want to lower my car at this point, would it look weird with the tire size that comes with the rims or would it look better with the 235/40/18?
Old Mar 20, 2007 | 08:08 AM
  #408
JimmyH's Avatar
I had some light curb rash on mine, I just sanded it with a dremel and painted it using my Sterling Mist touch up paint. It matches almost perfect.
245/45/18 is pretty big. I am running 235/40/18, almost same diameter as stock. Just a little wider. I get no rub.
Old Mar 20, 2007 | 08:11 AM
  #409
99MAXSE-L's Avatar
your car looks good with those rims. Obviously lowering it will make it look hotter, but that doesnt look bad at all.
So with the bigger tire size, overall the car will just look bigger and more of a 4x4?
Old Mar 23, 2007 | 01:57 PM
  #410
hiren_patel_83's Avatar
Lumber Question for you
Originally Posted by Lumberg™
check my sig...also I have stock 225/45 tires on now, i need some new ones...do you think i should go with 245/40 or 235/40?
hey lumber, what kind of springs are you using for your maxima. Those 35 rims look hot man. I like the way how theere is not much gap in between.
Please assist me with lowering my car, i've got the g35 replicas from ebay and they look great.
Old Mar 23, 2007 | 02:05 PM
  #411
maxwannabenow's Avatar
Those rims really look hot with the sterling mist!! That is definently my next favorite color next to black of course. I think the clear sidemarkers would really look good also.
Old Mar 23, 2007 | 04:21 PM
  #412
irish44j's Avatar
retired moderator
5th gens get rubbing with the 245/45/18 in the rear....so your 4th gen will to.
Go 235/40/18 all-around, FTW.
Old Mar 25, 2007 | 04:52 AM
  #413
S13ORLANDO's Avatar
Curb Rash on G35 coupe wheel
Thanks,
I will try the dremel tool. I bought all four G35 coupe (7 spoke) for $225!
One wheel has some bad curb rash. The guy with the coupe said he wanted
perfect "looking" wheels.He bought the EBAY G35 Knock offs for God knows how much? He then had to buy spacers to clear the Brembo calipers.
So bad for him,good for me.That's $225 for all four($56.25 each).
So I am going to try and light sand the wheels? Then paint them.
I thought about "sandblasting" and then powder coating.I could probably buy
the 19'" G35 wheels or some VOLKS/RAYS for what the machine shop would charge for all that work?
Anyone got any ideas besides a dremel to smooth out the curb rash?
thanks,
Bob
Orlando Florida
***an_bob@yahoo.com
s13orlando here and on www.floridadrift.com
Old Apr 1, 2007 | 04:33 AM
  #414
tyrotrader's Avatar
Ebay 18 G35 replicas
http://cgi.ebay.com/ebaymotors/18-8-...QcmdZViewItemI know several have "not recommended" these wheels on ebay. However, they state that they are 8" wide and "to manufacturer's specifications".
I had previously seen that they were 7.5" and had yellow hubs.
Have they been improved/changed - ie. now might be ok?
Has anyone weighed/measured one recently to see if they match oem?
Seriously considering buying these to avoid hastle of buying used from an unknown individual - etc.
Old Apr 1, 2007 | 08:21 AM
  #415
Lumberg™'s Avatar
on this site too damn much
Thanks man....I got Tein S-Techs
Old Apr 4, 2007 | 08:05 AM
  #416
seshead's Avatar
Hey guys,
Just picekd up a set of G35 Rims 18x8.
Two Questions:
1) Which tire size would you recommned for these wheels for an 01 20th anniversary on stock suspension (no plans on dropping it soon). Want to make sure I get a good size to hide some of that gap if im planning on not getting it dropped.
2) Which lug nuts should I use? Ones that came with the G35 rims or my stock 17" lugs?
Your help is appreciated. Sooner I get an answre the sooner they come on
Old Apr 4, 2007 | 09:34 AM
  #417
00MaxSE's Avatar
Pointy Elbows
Originally Posted by seshead
Hey guys,
Two Questions:
According to the tire calculator sticky, 245/40/18 is the closest to stock diameter, so that size would be ideal unless rubbing would be a problem.
I would use the lugs that came with the G rims.
Old Apr 4, 2007 | 10:11 AM
  #418
seshead's Avatar
Thanks 00MaxSE!!
So 245 wont rub with stock suspension? Can anyone else provide input on this?
Old Apr 4, 2007 | 12:11 PM
  #419
JimmyH's Avatar
Hey guys,
Two Questions:
235/40-18 is the size you want to use, 25.4" dia. Stock Max size is 225/50-17 right? That would be 25.8", close enough.
If you go 245, you might get some rubbing initially when turning the front wheels. Plus I dont think 245/40-18 is a very common size.
I used the lugnuts that came with my Maxima, which originally had 16" wheels.
Old Apr 4, 2007 | 12:18 PM
  #420
JimmyH's Avatar
Thanks 00MaxSE!!
I would bet it would. When I went from my stock 215/55-16 to 235/45-17, I got some rubbing when turning for a couple days. It must have pushed the wheel well liners in or worn them in because it stopped after that.
When I went to 235/40-18, it was the same width I was running with 17's and I did not get any rubbing then.
Old Apr 4, 2007 | 01:31 PM
  #421
seshead's Avatar
thanks for the input Jimmy
Old Apr 4, 2007 | 02:51 PM
  #422
sooner02r1's Avatar
Anybody got pics of the 18" 7 spokes on a max powder coated black?? I'm getting some next week and I'm thinking about getting them powder coated before I put them on, but I'd like to see some first.
Old Apr 4, 2007 | 10:35 PM
  #423
Greeneyes's Avatar
They fit... Front ones will stick out a bit... but I got mine on there... and they stuck on there... The rear ones youll have to pound in the cap on the center of the wheel hub to get them to go in.
Old Apr 5, 2007 | 12:23 AM
  #424
SilverGLE's Avatar
I'm watching you, boy...
Or just get spacers for the front and rear. That'll also work.
FYI: I used the stock G35 tire size, 245/45/18 and it rubbed like crazy in the rear with any weight in the car besides me. 225/45/18 works w/o rubbing, while 235/40/18 is the ideal size.
sooner02r1: Check out this thread for someone that was selling G wheels he'd had powercoated not too long ago...
Old Apr 6, 2007 | 06:00 AM
  #425
sooner02r1's Avatar
I hope this question hasn't already been answered. I have read most of this thread and did not see an answer. Do the 245/45s that come stock on the rear of these rims rub on the inside of the tire?? If so if you ran a small wheel spacer, would that work?
Old Apr 8, 2007 | 08:26 AM
  #426
seshead's Avatar
when putting on these rims, which lug nuts should I use? G35 lug nuts or thee maxima lug nuts. Someone help! wanna put them on tomorrow
Old Apr 8, 2007 | 07:59 PM
  #427
irish44j's Avatar
retired moderator
no, that size rubs on the OUTSIDE of the tire..because of the 30 offset (compared to 40-45 stock) there is plenty of room on the inside....
Old Apr 8, 2007 | 08:00 PM
  #428
irish44j's Avatar
retired moderator
both will fit fine. I actually bought new, longer shank lug nuts to make them easier to get on and off compared to teh "acorns"
Old Apr 9, 2007 | 07:28 AM
  #429
Gismo-T's Avatar
B!tch We Got a Problem
Hey irish,
Do you have pics of teh longer lugs that you're using?
Old Apr 9, 2007 | 10:28 PM
  #430
sooner02r1's Avatar
Here's another question for someone more knowledgeable than me. I love rims that look staggered. If I run 235/40s in the back on the 18" G coupes on my lowered 5.5, can I run a small spacer on there without rubbing? If so, could do you think I could have the fenders rolled and fix it? I love the look of beefy rears sitting right out under the fender.
Old Apr 9, 2007 | 11:58 PM
  #431
Maxima03GLE's Avatar
Which wheel combo is best for 03 maxima's
I am looking at two sets of G35 wheels and cant decide which will be best for my ride. One is the 19" and the other is the 18" G35 wheels. Can you guys please help me with this decision. I'm riding on stock springs. I dont want to drop my car since i do alot of highway traveling. I dont know how bad the 19's rub compared to the 18's. Is it a huge difference? Thanks for any help. you can email me at arick.house@gmail.com. Thanks
Arick
Old Apr 10, 2007 | 12:03 PM
  #432
seshead's Avatar
just wanted to say thanks to all that have helped with my G35 rim issues. I mounted them on yesterday and they look frigggin' sweet!!! (pics to come). I went with 245/40/18 all around on stock suspenison. rides like a dream !
Old Apr 10, 2007 | 03:52 PM
  #433
sooner02r1's Avatar
Got my 18" G coupes on my car today. Stock size tires, Maxspeeds, and no rubbing yet, however I think it will look better with smaller tires in the rear. I'll post up pics in a day or two when I get it all cleaned up.
Old Apr 10, 2007 | 06:17 PM
  #434
Deckdout2's Avatar
Play with my balls
Thanks Greeneyes. That's the answer I was looking for. Good thing I have 4 5mm spacer plates that I couldn't sell. I'm going to use those to bring the wheel out a little so I won't have to do any pounding.
Ok, off to search the forum regarding 5mm spacers w/o using extended lugs. I remember reading about this a bit, but now that I'm going to do it, just need to refresh my memory.
Happy ridin' dirty.
Old Apr 10, 2007 | 06:24 PM
  #435
irish44j's Avatar
retired moderator
Arick
er...as long as you get the correct profile/size tire, the 19s won't rub any more or less than the 18s......
If you're not dropping it though, go with the 18s. Bigger-diameter rims accentuate the wheel gap...
Old Apr 10, 2007 | 06:26 PM
  #436
irish44j's Avatar
retired moderator
Originally Posted by Gismo-T
Hey irish,
uh, no....they didn't qualify as "photogenic" haha....
just go to an auto parts store and look at the lug nuts there. You need 6x1.25 size (IIRC, but double-check). you will see three types:
1. short little open-ended ones
2. short little acorn-looking ones
3. longer ones
get the longer ones
Old Apr 10, 2007 | 09:53 PM
  #437
thanks irish. with th 19" 35's what would be the proper size tire? The rear wheels are wider no? can you run the same size tire all around on that rim? "if" i was to even my car out a inch or so what is the best way(and by best i mean least loss of ride comfort and least damage to my car) that you recommend? My bro has a 03 TL type s dropped with koni and its like a fricken log truck. I dont want my teeth to hurt from my car Thanks again for all your help here.
Arick
Old Apr 10, 2007 | 11:41 PM
  #438
joebangaa's Avatar
245/40/19
eibach/h&r/progress for the drop paired with illuminas
Old Apr 11, 2007 | 09:35 AM
  #439
00MaxSE's Avatar
Pointy Elbows
Arick
245/35/19
Old Apr 11, 2007 | 09:43 AM
  #440
So is it the 35 or 40? which spring is best will the illuminas? (I will be living in nola so the roads are horrible.) no rubbing with 19's?
respect
arick
