Wheels/tires Sticky? G35 wheels on maximas
Old Jan 2, 2006 | 06:20 PM
  #81
Lumberg™'s Avatar
on this site too damn much
thanks ill go with 235/40 then...think im gonna go with Falken Ziex Ze 512...seem like a great tire of the price. What do you guys think?
Old Jan 2, 2006 | 06:52 PM
  #82
irish44j's Avatar
retired moderator
Most people like the Ziex, though there are some detractors as well. I have used the Ziex 512's twice, and while it is a good tire, I strongly suggest that you use the Toyo Proxes 4. It is available in that size, not much more $$ than the Ziex, and is a superior performer in all categories, IMO. Plenty of threads on tires elsewhere, though....so let's keep this thread talking about the wheels!
Old Jan 4, 2006 | 09:05 AM
  #83
kramarz99
Hey, Quck Question....why Rear Wheel From G35, The Center Cap Won`t Fit On My 2000 Maxima? I Had To Take It Off Because There Is No Room?
Any Idea?
Old Jan 4, 2006 | 02:05 PM
  #84
Lumberg™'s Avatar
mine's not a 00 but I have heard people with 4th gen's have the same problems. I just put my wheels on and my center caps went on with em without popping out. The rears are def pokin out a little but still are on there pretty good.
Old Jan 4, 2006 | 04:16 PM
  #85
WaarrEagle's Avatar
I am looking for some 18" OEM G35 wheels. I am having a hard time finding any without tires. If I get some with the OEM tires (225/45 up front and 245/45 in the rear) would either fit on a lowered 4th gen. I know the correct size is 235/40 but if all i can find is rims w/ tires I don't want to just throw them away. I was thinking of just replacing 2 of them with the same as whatever is on the other 2 and then I would have 4 matching tires (in a wrong size, I know). Any thoughts on this?
Also, if anyone has any of these for sale send me a PM. I have been browsing the G35 forums.
Old Jan 4, 2006 | 05:07 PM
  #86
irish44j's Avatar
retired moderator
Any Idea?
you have to dent in the sides of the OEM dust cap to make the centercaps fit. Use a ball-head hammer and dent it in all the way around.
Old Jan 4, 2006 | 05:09 PM
  #87
irish44j's Avatar
retired moderator
245/45 will rub in the rear, especially on a lowered 4th gen. It won't rub all the time, but will over dips, speed bumps, etc - especially if you have people in the back seat or weight in the trunk...
I found both of my sets without tires
Old Jan 4, 2006 | 07:19 PM
  #88
tripleGmax's Avatar
im selling mine, ill pm you.
Old Jan 4, 2006 | 10:09 PM
  #89
WaarrEagle's Avatar
Sorry to keep bugging you but you seem to be an expert. I am looking at a set with 245/40/18's all the way round. Is that enough of a difference to keep it from rubbing vs 245/45?
Old Jan 6, 2006 | 06:25 PM
  #90
irish44j's Avatar
retired moderator
you "should" be ok, but a 245 is on the wide side for an 8" wheel. technically it's within spec (depending on tire), but handling and ride will not be as good because of the steep sidewall angle. Your speedo will show a bit slow in that diameter/aspect ratio as well.
If they're a good deal, go with it, but plan your 2nd set of tires to be 235/40
Old Jan 6, 2006 | 06:59 PM
  #91
02theMax's Avatar
Well I bought the 05 G35 19" double spoke rims. I can't wait to put them on after I install the springs. Can someone photo shop them on a 5.5 gen for me please. I've seen the single multi-spoke ones from the 04 model (I believe) but I haven't seen a 5th gen with the double spoke 05 style G35 rims. Tire sizes are staggered with 225/40/19 up front and 245/40/19 in the rear. Hopefully they don't rub with the car being dropped with progress springs, any comments? Thanks
Old Jan 7, 2006 | 01:11 PM
  #92
irish44j's Avatar
retired moderator
why don't you just go outside, jack up the car, and put one of them on...take some pics....then put the other wheels back on. It would take longer to do a photoshop!
245/40/19 may have some major rubbing...I run 235/40/18, which are like 1.5" in diameter less than what you have.....definitely do a test-fit!!!
Old Jan 7, 2006 | 03:04 PM
  #93
02theMax's Avatar
I haven't got the wheels yet so I can't take pictures. If they rub then I'll have to sell them. Thanks for the info.
Old Jan 8, 2006 | 09:30 AM
  #94
irish44j's Avatar
retired moderator
...or you could just put the correct sized tires on them to keep the diameter correct.
Old Jan 8, 2006 | 09:38 AM
  #95
02theMax's Avatar
Yeah, I was thinking that after. Just sell the two tires and buy a smaller size. Maybe 245/35/19's in back to keep the staggered look? What do you think Irish.
Old Jan 8, 2006 | 11:03 AM
  #96
irish44j's Avatar
retired moderator
I would definitely use a tire calculator to try and determine what will get you closest to stock diameter...that's what you want!
I think there's a link to one here in the wheel/tire stickies. You may also have to trim the little tabs on the back fenders (where they attach to the back bumper...reach in the wheel well and you'll know what I'm talking about)...I had to do this to prevent rubbing with my snow tires on 8" wide wheels/33 offset 235/50/17 tires
Old Jan 8, 2006 | 06:19 PM
  #97
Kevlo911's Avatar
Kevlo for President
4th gens with the G35 18" wheels, do they wheels rub?
Old Jan 8, 2006 | 07:51 PM
  #98
Lumberg™'s Avatar
mine don't...im dropped on s-techs with 225/45
Old Jan 12, 2006 | 03:54 PM
  #99
wesnine's Avatar
Makers Mark
Does anyone actually have the OE Wheel Distributors replicas on their Max? Mine didn't fit, ugh.
Old Jan 12, 2006 | 04:56 PM
  #100
rchun08's Avatar
touch up for curb rash
question? is there anything i can do to help curb rash..i know the color is hard to duplicate and i dont want to have it refinished becuause it will look all off color...does inifinit dealers have any color thats close to touch it up?
let me know thanks..,
next set of tires will be 235/40/18..michelin sport a.s
Old Jan 18, 2006 | 03:38 PM
  #101
wesnine's Avatar
Makers Mark
I don't understand how these (the replicas) will fit a 2001 GLE with a 30mm offset. I have taken them two different places to no avail......
Old Jan 19, 2006 | 11:10 AM
  #102
irish44j's Avatar
retired moderator
there is a difference between the wheels fitting (which they should) and the centercaps fitting (which they might not)
which is is?
Old Jan 19, 2006 | 11:37 AM
  #103
tkorpus's Avatar
Originally Posted by tkorpus
I read the whole thread, but did not see a definitive answer to this question. I bought a set of the G35 18's and was planning on wrapping them in 245/40/18 to put on my 2003, but I want to make sure it will not rub. I am dropped 2" on Ksport coilovers so there is some flexibility there. Is anyone actually running this setup yet?
There is a very good chance they will rub. In fact, I'd say it's an excellent chance if you are dropped 2" that they WILL DEFINITELY rub. Of course, what tire you choose will also have an effect - some have wider tread width/section widths vs. others.
put 235/40/18 on them, and avoid the hassle of rubbing. That size works well.
Thank you irish for the good information. I went with the BFG KDW NT 235/40/18 on the G35 wheels and I am very happy with this setup. No rubbing so far with about a 2" drop. As a bonus, this particular tire in this size is reinforced so it actually has a higher load rating than the 245/40/18 (95 vs. 93). This is way better than the 91 that most tires in this size come with.
As a side note for others, I did have to tap in the rear hub dust caps with a hammer in order to get the wheel dust caps to fit properly.
Old Jan 19, 2006 | 06:44 PM
  #104
02theMax's Avatar
Well I finally installed springs and 19" G35 rims and no rubbing. I only installed (eibach) springs in the front and left the rear stock, it looks and handles great! Now I just need to learn how to post pictures?!?! Thanks for all your great info Irish.
Old Jan 19, 2006 | 07:55 PM
  #105
02theMax's Avatar
Here's some night shots. I'll post better pictures in the member's rides section tomorrow.
Old Jan 20, 2006 | 08:46 PM
  #106
irish44j's Avatar
retired moderator
looks nice man I was just admiring those wheels on my buddys G35 today while we were in the golf course parking lot loading up.
Old Jan 20, 2006 | 11:11 PM
  #107
02theMax's Avatar
Thank you Sir!
Old Jan 21, 2006 | 07:02 PM
  #108
fia_f1's Avatar
I have read this whole post and have not yet seen this question. If I have missed the answer sorry (I am a newbie), kindly point me in the right direction and I will plod along.
A friend of mine has a set of 17"'s G35 (6 Spoke) with a good/new set of rubber. He is going to give them to me. I just need to make sure they fit.
The rims are 17x7.5 and 17x8.
The tyres are 225-50 and 235-50.
I have an '01 (w/16"'s) not lowered (yet).
Does anyone know of any side effects from running the two different size tyres? Of course once this wear, the next set will be the same size.
Thanks in advance...
02theMax... Great job on those rims/tyres
Old Jan 21, 2006 | 07:39 PM
  #109
02theMax's Avatar
Hey fia f1 thanks for the compliment. You should be fine with that wheel / tire setup. I don't see any draw backs running a staggered setup, I think it actually compliments the looks of the 5th gen. You could fit a 245 size tire out back if you really wanted to make your car look a bit more aggressive or you could just run the same size tire front/back. If I were you I'd do a mild drop with tien h-tech's or eibachs or H&R's and run a wider tire out back to finish things off. With my setup I only dropped in the front with eibach's and left the rear stock height and all stock struts. The bigger 19" rims fill the gaps nicely plus my setup is staggered. Hope this helps you out.
Old Jan 21, 2006 | 08:08 PM
  #110
irish44j's Avatar
retired moderator
There's really no performance side effects, other than the fact that you can't rotate the tires (235/50 in the front WILL rub).
I am now using my G35 coupe 17's (same as yours) as winter wheels - I have 225/50/17 snow tires on the front and 235/50/17 on the rear (got them from a 350Z guy, used). The backs DID rub over highway dips and speed bumps, until I shaved down the little lip where the rear bumper meets the body of the car (reach into the wheel well and you'll see what I mean)...now it no longer rubs. Some tires are a little wider than others, but you should be fine I would guess.
Old Jan 27, 2006 | 07:13 PM
  #111
02theMax's Avatar
Old Feb 7, 2006 | 08:56 AM
  #112
Mungo's Avatar
This is great info guys. I just picked up an 03 titanium edition and the rims were all curb rashed. ruined a nice looking set of rims. I picked up a set of the ebay replica's. I had replica rims on my last truck and had no issues. Should be going on Saturday. will post pics. Cant wait!
Old Feb 7, 2006 | 08:58 AM
  #113
tripleGmax's Avatar
great info....that you didnt use. i swore i read that the replicas dont fit......
Old Feb 7, 2006 | 09:01 AM
  #114
Mungo's Avatar
I saw that post but I dont see that being an issue based on offset. I spoke to the company a few times and they assured me they fit. I will post my findings.
Old Feb 7, 2006 | 09:02 AM
  #115
tripleGmax's Avatar
hope they fit for you.
Old Feb 7, 2006 | 09:43 AM
  #116
Mungo's Avatar
Did wesnine ever say why his set didnt fit? Has anyone else had a issue with fitment with the replica's?
Old Feb 7, 2006 | 09:56 AM
  #117
MetaOrbit's Avatar
Got Projectors?
He never said why they didn't fit. Just that they didn't. Seemed that he was complaining about the centercaps not fitting? Unfortunately he never seemed to tell anybody what the real issue was.
I really think that if the specs they post on the replicas are correct, they should fit with zero problems. 7.5" width, 35mm offset, and the correct hub bore, what else could prevent them from fitting? (Unless the spokes hit the calipers, but the odds of that happening are slim to none).
Old Feb 7, 2006 | 10:00 AM
  #118
Mungo's Avatar
I just find it hard to believe that the company would blatantly lie like that. Now I know that it is eBay but this company seems legit. I've called 3 times, each time I spoke to a different person and the phone was answered quickly and very politely. The last time I spoke to the account dept to get the tracking info. Better experience than any other eBay service I've rec'd.
That said, it will suck if I have to eat crow and these dont fit.
Old Feb 7, 2006 | 10:03 AM
  #119
Jeff92se's Avatar
I'm needing a caw
Why buy them at all? When you put tires on them, it's actually more expensive than a set of real 8" versions with low mile Michelins. Never made sense to me.
Old Feb 7, 2006 | 10:14 AM
  #120
Mungo's Avatar
I have a tire connection so I will be getting my tires at cost and the place will mount and balance everything for next to nothing. I think it will cost me a 30 pack.
That said, I am into these for 850-900 shipped, mounted and installed. I looked around and didnt see any 'real' infiniti's available at that price range. Some were close but I dont want tires that already have 20k on them even if they are Pilots. I get brand new tires and rims. For a daily driver I dont see a difference in the quality of these rims and the 'real' rims. I may be worng but I dont think so. Can anyone vouch that these rims are not of good quality? I havent seen anyone say otherwise.
As far as fitment the only issue people have reported are with centercaps. I can make that work. Not sure if there is enough space for a wheel spacer but that may be an option as well.
