18x8 on 245/45/18? ok?
you won't have any problems, except your speedo will be off a hair.
245/40/18 = 0.5% fast.
when your speedo says 60mph, you will actually be going 59.7
245/45/18 = 3.2% slow.
when your speedo says 60mph, you will actually be going 61.9
http://www.miata.net/garage/tirecalc.html
Originally Posted by vervaak
your new wheels on that you bought from Kev?
hehehe...i would like to stick with my old set of rubber if possible.broke after buying new set of wheels
they're on...
I have the g35c's w/ the 245/45/18 in the rear. They fill out the fender very well and look great on the rim, however there is a very slight rub in the rear where the bumper, quarter panel are mounted together. If you keep the air pressure down around 30-32 psi the rub is very slight so long as you're aware of it. You could also trim the flange before the screw that holds the two pieces together. This is all with no drop currently in the rear. I'd recommend going with a 235/45 or 235/40 on (18x8) rims. 235/45 is the closest to stock, however they make very few tires in this size.
Originally Posted by tkorpus
What is the offset of the wheels that these are on? Are they G35 wheels? Any rubbing?
SWEETSOUND2001
12-27-2001 03:45 PM
Vic
02-13-2001 07:49 PM
Maxx Atlanta
11-11-2000 10:42 AM
