19x8.5's w/ 43mm offset???
Old May 2, 2006 | 07:12 AM
Nismonkey's Avatar
Hey guys, I've google the crap outta this, but I think hearing it from fellow Maxiam guys will make me feel better.
I've got a set of 245/35/19 tires that I plan to mount onto 19x8.5 wheels. Thing is the wheels have a 43mm offset. Will that rub???
I'm running 245/35/19's on a 19x8, 35mm offset setup, and I've had no issues at all.
If I'm using the offset calculator right, a 43mm wheel will push the outer edge of the wheel OUT 2mm??? and the inside edge of the wheel IN 12mm???
Thanks!
Old May 2, 2006 | 03:05 PM
C3nthusiast's Avatar
You should be fine. You probably have at least an inch plus clearance inside and 1/2" outside. I run 245/35-19 on 19 x 9.5's 45mm offset in the rear and 235/35-19 on 8.5" rim 44mm offset on the front w/ my 4th gen. The 5th gen has much more clearance.
Old May 2, 2006 | 03:43 PM
Nismonkey's Avatar
Yeah, I did some measuring yesterday...I think I've got "some" room!
We'll see...I'd hate to drop the $$$ and then have my wheels not fit or rub to all *&^%
Old May 8, 2006 | 02:25 PM
Nismonkey's Avatar
BUMP...
Anybody else running these #'s with their 19's on a 5.5 gen?
Old May 10, 2006 | 07:01 PM
MIKE DEGUZMAN's Avatar
its too high of an offset imo
itll look sunken in n itll prolly look horrible without spacers
u should be worried about its stance b4 its rubbage
Old May 10, 2006 | 07:04 PM
Ammi's Avatar
350 Detroit Muscle
I would use 5mm spacers
Old May 10, 2006 | 07:54 PM
Nismonkey's Avatar
Yeah, I've thought about using spacers.
Man, I sure wish someone had pictures of this set up!!!
Old May 11, 2006 | 10:27 AM
Stalldaworld's Avatar
what are you doing with your other set of tires? i have a set of 19x8.5's. im looking for tires. i was thinking about running a 235/35 or a 245/35 on a 35 mm offset. i dont think ill have any issues. i am still looking for tires tho...
Old May 11, 2006 | 03:06 PM
Nismonkey's Avatar
I'm hoping to sell my current wheels then purchase new ones with the $$$.
Old May 11, 2006 | 09:30 PM
drftr915's Avatar
help!
a little off ur guys topic, but i'm about to buy som volk's, ev3's 19x8.5 in the front and 19x9.5 in the back and was curious as to what tire size i should get and if it would be a good fit on a 97.
plan to get the tein s tech's soon as well (-2.2) front,(-1.7) rear would this make any problems for me
Old May 13, 2006 | 07:40 AM
if u want to sell you tires seperately and they are in good shape hit me up!!!!!!
Old May 13, 2006 | 01:42 PM
Ammi's Avatar
350 Detroit Muscle
you need to know the offset
Old May 13, 2006 | 03:34 PM
Nismonkey's Avatar
PM sent man!
Old Jun 1, 2006 | 07:33 AM
kajeno's Avatar
How much clearance do you have in the back and the front when the wheels are fully turned? I am looking at a set that has a 45 offset. Thanks.
Old Jun 3, 2006 | 08:49 AM
limsandy's Avatar
Let the old thread die!
Old Jun 3, 2006 | 08:15 PM
Nismonkey's Avatar
Just buy my wheels! They're 35mm offset...
RinconI30
Jun 11, 2016 08:25 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
MplsMadMan
Sep 11, 2015 07:54 AM
