Smaller Can Mean Better!
Old Jun 3, 2006 | 05:05 PM
dr-rjp's Avatar
While bigger wheels look cooler, if you want to be faster off the line, go smaller. Keep in mind that there is a direct inverse relationship between tire diameter and final drive ratio.
For example, the smaller the tire, the bigger the ratio, the greater the low-end acceleration. Conversely, the bigger the tire, the lower the ratio, and the less will be the low-end acceleration -- BUT -- the higher will be the top end speed.
msellas
Sep 23, 2015 09:16 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
umnitza
Sep 1, 2015 01:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
spidgeon
Aug 18, 2015 05:46 AM
