Are 245-45-18 size tires okay for 2004 maxima SL?
Old Aug 30, 2006 | 05:54 PM
Killah Kane's Avatar
I have a 2004 SL and am going to buy 18 wheels and plan on getting 245-45-18 tires. Will I have any problems with this size? I am pretty sure I wont, because I know that these are the same size tires that are OEM on the SE maxima, but I dont know if they will be a problem on the SL due to the slightly different suspensions...what do you guys think?
Old Aug 30, 2006 | 06:17 PM
NmexMAX's Avatar
dot dot dot ...
They will be fine depending on the width. 7.5-8.5" should be okay, anything more or less is pushing it in either direction. How wide are the wheels you're purchasing?
Old Aug 30, 2006 | 06:55 PM
They are 18 x 7.5
Old Aug 30, 2006 | 08:51 PM
limsandy's Avatar
You'll be fine. Next question?
Old Aug 30, 2006 | 08:57 PM
NmexMAX's Avatar
dot dot dot ...
I'd go wider.
Old Aug 31, 2006 | 04:52 AM
04BlackMaxx's Avatar
I have an SE but im planning on going 18X8.5
Old Aug 31, 2006 | 05:53 AM
NmexMAX's Avatar
dot dot dot ...
That be the size I'd go with.
ah2002
Mar 9, 2016 01:42 PM
MplsMadMan
Sep 4, 2015 02:23 PM
District
Aug 15, 2015 08:23 PM
Max8
Aug 15, 2015 07:06 AM
soon2ownmax
Aug 13, 2015 02:19 PM
