Wheel Balancing on stock 17' rims
Old Jan 15, 2007 | 07:06 PM
Andrew's Avatar
Quick question..
I'm putting new tires on my stock 17" rims. The weights for the wheels are 'inside' the rim and are glued in. There's no reason to put the other wheel weights on the outside like they do with steel rims? I'm getting these done from a friend of a friend and just wanted to be sure. I hope I'm making sense here.
Andy
Old Jan 16, 2007 | 08:15 AM
bladerunr's Avatar
If they position the stick-on weights correctly, then there is no reason to use the tap-on weights on the outside of the rim. I'll never go back to the tap-on weights again, they ruin the rim. Make sure they stick the weights on the inner and outer part of the inside of the rim - that will give you the best balance.
Old Jan 16, 2007 | 08:20 PM
Andrew's Avatar
ok, i thought so...Thank you!
Old Jan 16, 2007 | 08:34 PM
SEmy2K2go's Avatar
Go BUCKS!!!
They can also mount the tap-on weights on the backside of the wheels if needed, but I also prefer the stick-on versions to dave the edges on the wheels.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
dcam0326
Sep 8, 2015 11:02 PM
