225/45/18: rubbing issues
Old Jan 29, 2007 | 10:17 PM
maxim82's Avatar
heres the deal in the front i got 225/45/18 rear 245/45/18 and my car is dropped 1 1/2" front and 1 1/4" rear, my problem is that all four sides are rubbing against the fenders when ever i hit a bump on the road or if i corner hard, i want to have one tire size all around so what tire size would you recommend that wont be rubbing at all?
Old Jan 29, 2007 | 11:30 PM
maximariceboi's Avatar
whats the offset of your wheels??? you should be fine if you were using 235/40/18 all around
Old Jan 30, 2007 | 06:07 PM
maxim82's Avatar
im not sure of the offset its the g35 rims
Old Jan 30, 2007 | 07:30 PM
irish44j's Avatar
retired moderator
g 18's are 30mm offset
g 17x8 are 33mm
g 17x7.5 are 30mm
g 17x7 are 40mm
you should be running 225/40/18, not 45 profile.
Old Jan 30, 2007 | 07:38 PM
maxim82's Avatar
whats the difference between the 235/40/18 and the 225/40/18? how come everyone keeps saying that the 235/40/18 are what i need
Mar 12, 2020 12:06 AM
Serotta33
Sep 17, 2015 12:14 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
thenewguyy
Sep 12, 2015 11:12 AM
