Can you put cables on 6th gen SE?
Old Feb 6, 2007 | 08:54 PM
george_rem's Avatar
Manual says you cant use chains, but what about cables?
Old Feb 7, 2007 | 02:49 PM
irish44j's Avatar
retired moderator
if you want to tear up your aluminum wheels.....
if you live in an area where chains/cables are needed, you really should invest in some snow tires...
Old Feb 7, 2007 | 02:51 PM
george_rem's Avatar
I thought it was a question of clearance, not of scratching the wheels.
Old Feb 7, 2007 | 04:04 PM
irish44j's Avatar
retired moderator
I don't see why there would be a clearance issue if you're on stock wheels. after all, people put MUCH wider wheels on their maximas with no problems.
I figured they said not to do it so as not to scratch the faces of the aluminum wheels
Old Feb 7, 2007 | 04:07 PM
george_rem's Avatar
Wider than 245? You sure? One reason the turning radius is so lousy is the large width of the tires, so clearance is at the limit already.
Lakersallday24
Nov 7, 2024 07:31 PM
schmellyfart
Sep 25, 2015 04:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
