Help For Those Who Don't Check Their Air Pressure
Originally Posted by CanadianMoFo
People who don't check their tire pressure regularly are forced to buy new tires more often. Simply solution, it's a stupidity tax really.
I've used a clone to those in the past. The problem is they relieve the tire valve, and hold pressure against an o-ring inside the sensor. The top of the tire valve isn't necessarily flat or consistent enough to seal air pressure. It may work with some valve stems, and be miserable with others.
Mine were constantly leaking past that oring, and within a day or so, letting the tires go flat. At times, if I didn't dial them down as tight as possible, they'd audibly leak. It's probably why it's not certified for aviation use.
Paul
Paul
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
