Fitment with 19x8.5 SSR Comps
These wheels have a 42mm offset and clear my BBK by a mile... however im worried about the distance between the inner edge of the wheel and the coilover.. no tires on them right now and i have about the width of an index finger between these two. Should I get 235/35/19s that will pull the sidewall inwards to decrease the possibility of rubbing against the coilover or will 245/35s be ok?? I guess I could always run spacers if needs be.... thanks guys,
Grant
Grant
i'm not sure if this will help...but its worth a shot
I use to have a 4th gen with progress/agx....and I ran 245/40/18 on my 18x8.5 SSR comps...it had zero problems...this is equivalent to 19x8.5 with 245/35/19...the OD is nearly identical
I'm running 19 x 8.5 on the fronts and 19 x 9.5's on the rears. The tires are 245 / 35's front and 255 / 35's rear I have yet to rub at all.
To answer your question the 245 / 35's will work fine. If nothing else where ever you buy your tires so long as you don't role with them then you can exchange them for a different size.
steveyphat
09-15-2015 03:43 PM
