245/45/18 Rub?
Old Sep 5, 2007 | 05:43 PM
MaxFanatik's Avatar
245/45/18 Rub?
does 245/45/18 rub with a 2inch dropp on a 4th gen???
Old Sep 5, 2007 | 06:52 PM
!PrjctMax!'s Avatar
They fit perfectly on mine! lol...jk, I know that's the stock size for my car
Old Sep 5, 2007 | 07:40 PM
96blkonblkse's Avatar
I can almost garuntee you will rub. It is over 1" bigger in diameter. Especially with a 2.2" stech drop theres a 99% chance it ill rub in the front. Ideal size for 18" rims are 235/40/18. 245's you can get away away with a 40 series.
The offset of the wheels will also play a factor in rubbing. but they will probably rub.
The Law's Avatar
I R The Law
What is the offset of the rims? I know that when I had 245/45/18 on my eibach drop with +33 offset, I'd rub only when going over dips.
Old Sep 6, 2007 | 03:06 PM
MaxFanatik's Avatar
im not sure the offset ofthe wheels didnt buy them new
Old Sep 6, 2007 | 03:07 PM
The Law's Avatar
I R The Law
The offset should say on the rim some where.
Old Sep 6, 2007 | 07:27 PM
maxima985spd
you should do 245/40-18
Serotta33
Sep 17, 2015 12:14 PM
thenewguyy
Sep 12, 2015 11:12 AM
MikesChevelle
Aug 7, 2015 05:57 PM
RealityCheck
Aug 5, 2015 06:18 AM
Bucktown
Mar 20, 2001 06:18 PM
