Rear wheel studs, threads and spacers
Old Mar 13, 2008 | 12:22 PM
Colonel's Avatar
Old Fuddy Duddy
OK. I have put G35 rims on my car. Previously, I had H&R spacers up front to clear my Blehmco BBK. With the new rims, these spacers are no longer needed.
I noticed that putting these 5MM spacers on the back make it look pretty dog gone close to flush.
I have been searching for safety issues related to how many threads are necessary for a "safe" lug. Matt93se said a MINIMUM of 9 threads (which I am assuming is one complete rotation of the lug). Since he deals in metal, I figure that’s a good point of advice.
Currently I can only get 5 turns and when I torque it down to 80 FT/LBS, I get about 6 total turns. Obviously not enough. Is it possible to get REAR lugs longer to accommodate the necessary length? I can purchase an H&R kit for 60 some bucks just to get the lugs (don’t need the spacer).
Is there a cost effective solution to getting just rear lugs?
Old Mar 13, 2008 | 02:41 PM
Armon's Avatar
http://ichibausa.com/nissan3.html
Old Mar 13, 2008 | 05:07 PM
MyownNismo's Avatar
Future Camaro SS owner
H&R says 8 turns. Got the paperwork sitting in front of me.
Old Mar 13, 2008 | 07:07 PM
BLACKonBLACK98's Avatar
Former Vendor
extended studs ftw.
Old Mar 13, 2008 | 09:03 PM
MrDicks95SE's Avatar
Offset Is Everything.
i was running 7mm spacers with OE studs with no problems. i just rechecked them once a month. 7mm is pushing it, but with 5mm you should be alright. although I'd HIGHLY recommend getting extended studs, even if it is a 5mm spacer.
incubusjohnny
Nov 3, 2015 05:18 PM
Huttig2009
Sep 25, 2015 03:31 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
