fitting GOLD WRX STI Rims on an 1st Gen I30
Old Jan 27, 2011 | 11:50 PM
cefiro8701's Avatar
I've been presented with the delightful opportunity of picking a set for less than 400$ with tires.
Wheelspecs-
17x8 +53
tires are 225/45/17
question is what size spacer would I need to run this?
also, the centerbore seems to be small for the nissan hubcenter.
would the spacer take care of this? or do i have to get it drilled out to spec?
Old Jan 28, 2011 | 01:05 AM
VQ'rInWLA's Avatar
Wow thats a high offset. To pull it off and get closer to the fender, at least 15mm are in order.
Old Jan 28, 2011 | 05:09 AM
CustomLowz's Avatar
<--- Wants those wheels for his subaru
Old Jan 28, 2011 | 05:27 AM
phatboislim's Avatar
i think somebody about a year ago tried fitting these (bore related problem as the OP mentioned) and was disappointed...i hope for your sake you get them to fit
Old Jan 28, 2011 | 08:48 AM
That offset is extremely high. Gonna need to run huge spacers 20-25mm just to get them close to the fender. Now, as for the center bore of the rims, they'll have to be bore'd out for sure.
stevesmax
Dec 17, 2020 11:57 AM
Quickgtp
Apr 13, 2017 03:30 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
laflyer23
Aug 22, 2015 10:04 PM
criminalslang810
Aug 16, 2015 08:12 AM
