what tires to run?
Old Aug 5, 2011 | 04:55 PM
michael454rs's Avatar
what tires to run?
whats up everyone i picked up a set of 19' infinity rays couple months ago finally getting around to buying tires. what size tire should i run i was thinking about running 245/35/19 all around dont know if it would work since their staggered not alot 19x8 in front 19x8.5 in the rear, will i have issues turning with this tire. im not dropped but thinking of getting h&r lowering springs. also to get a nice look will have to run wheel spacer. thanks for the help. by the way this is for an 03 max
Old Aug 5, 2011 | 05:30 PM
Rhyno02's Avatar
I have 245/35's up front and 255/35s in the back. And I'm fine you could go 245/35 all the way around. Some people go with 245/40s, I guess it depends how low you are
Old Aug 5, 2011 | 05:41 PM
right now im at stock height. if i go 245/35 all around will i have an issue when getting the h&r lowering springs? are you running any type of spacer?
Old Aug 5, 2011 | 05:46 PM
Rhyno02's Avatar
You'll be fine with H&Rs lol. I have no gap up front and I'm good with the fronts. I do need to roll my rear fenders though. I don't have any spacers.
Old Aug 5, 2011 | 05:48 PM
they rub against the fender alot?
Old Aug 6, 2011 | 06:19 AM
Rhyno02's Avatar
No not alot but I'm alot lower then HRs too. It just bugs when it does
Old Oct 17, 2011 | 06:25 AM
04 commemorative's Avatar
Hi, first post here...we have a 1996 Maxima SE with 44 K orig miles. Time for tires and being that I can't start a thread I was wondering what tires someone here would recommend. Right now I have Michelin's and after 26K they have worn down faster than I would like.
Open for suggestions here. By the way....everything except the tires on it is....factory original....so far.
Old Oct 21, 2011 | 10:58 AM
Shift_Max's Avatar
I have had 245/35/19 and that worked very well. Only downside is the price of tires in that size. Expect to pay a nice amount for decent tires.
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
