245mm wide tire on a 9" wide wheel?
Old Nov 13, 2011 | 08:47 PM
wope's Avatar
Has anyone ever put a 245mm wide tire on a 9" wide wheel? I'm having rubbing issues (just a very slight rub in the front with hard cuts or bumps) with my current 255 mm setup and am considering swapping out to 245mm tires. Will the 245mm fit properly and will it look alright or will they look stretched out?
Thanks!
Old Nov 14, 2011 | 01:06 AM
IHAVEA2KMAXIMA's Avatar
You should list the full spec of the tires + wheels and your gen.
Ex: 245/40/18 for tires and 18x9 +30 for wheels on 4th gen.
Old Nov 14, 2011 | 07:54 AM
nismomaxct's Avatar
I have 18x9 +30 with a 245 on the front of my 5th gen and I have no rubbing issues. They do not look stretched at all.
Old Nov 14, 2011 | 09:06 AM
J2FRESH's Avatar
Thanks!
like 2k said
what's the full tire size? 245- ? /18
what wheels do you have?
what year max?
I personally had 18x9 rims on my 5th gen with 255-35-18 and never experienced any rubbing but i was also stock 4x4 ride height.
I now own a 4th gen 98 and currently have 18x9.5 with 245-40-18 and lowered about 3.5 inches or an inch from the ground to lip and have slight rubbing but thats only on sharp, hard cornering turns.
If you choose to go to a 245 you should be fine.
what is your current tire size 255- ? /18
Old Nov 14, 2011 | 10:42 AM
Puppetmaster's Avatar
I had 245/40/18s on an 8.5" wide and no rubbing. Definitely no stretchy look either; in fact they look pretty beefy, almost too beefy.
Old Nov 14, 2011 | 03:48 PM
wope's Avatar
Sorry, this would be for a 7th gen. 20x9 wheels 245/35/20 size tire. The 255s rub because very slightly in the front
Old Nov 17, 2011 | 08:08 PM
wope's Avatar
Does anyone happen to have a decent pic of their 245mm tire on a 9" wide wheel? I'm trying to determine if its going to look stretched at all.
Thanks.
Old Nov 17, 2011 | 11:36 PM
HNL2LAX's Avatar
225 will look stretched, 245 will fit nicely.
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
